Running hot - Victory Forums - Victory Motorcycle Forum
post #1 of 16 (permalink) Old 03-30-2013, 02:39 PM Thread Starter
lawnstriper's Avatar
Default Running hot
Why are these pipes getting this damn hot ? Even the heat shields are bluing.ImageUploadedByMO Free1364672320.562308.jpgImageUploadedByMO Free1364672333.729162.jpgImageUploadedByMO Free1364672350.241070.jpg
2001 V92C(sold)
2004 Kingpin
lawnstriper is offline
post #2 of 16 (permalink) Old 03-30-2013, 02:47 PM
lunaticrider's Avatar
Have you done a plug chop to see if your running lean? Lean = Hot. What pipes are they?
2012 Hammer 8 Ball - All upgrades are listed in my Garage
If racing was outlawed ... Then only outlaws would race ...
lunaticrider is offline
post #3 of 16 (permalink) Old 03-30-2013, 04:42 PM
RBL
Have you done performance upgrades with out a tune? Im guess your bike is running pretty lean.
2013 Cross Country,forged bars,JTD lowers, Madstad windshield mount.
RBL is offline
post #4 of 16 (permalink) Old 03-30-2013, 04:47 PM
half_crazy's Avatar
Intake leak, vacuum leak, low fuel pressure? How does it run?
2006 Victory Kingpin
half_crazy is offline
post #5 of 16 (permalink) Old 03-30-2013, 04:59 PM
pipes turn color from all the heat.
check exhaust gasket and check for air leak like the man said
post #6 of 16 (permalink) Old 03-30-2013, 05:31 PM
Default How long?
Been running hot for how long. Friend had a little V-Star and he had mufflers that were gutted. His turned blue. He ran that thing like that for years. We rejetted once but,he had gotten to rich of jets so we put it back to stock and he got more restrictive mufflers later on. Point being you bike is lean like everybody else has said. I take it it pops out the mufflers on deceleration? A little is ok, a bunch is not good.
Speedblue is offline
post #7 of 16 (permalink) Old 03-30-2013, 05:49 PM Thread Starter
Thanks for all the replies , going to take it and have it dyno-tuned. This is a bike I sold to a friend and the pipes were on it that way . We found out that the clamps for the mufflers weren't tight either. So they leaked also. They are a straight thru design as well, so probably wasn't ever re-mapped fuel wise.
2001 V92C(sold)
2004 Kingpin
post #8 of 16 (permalink) Old 03-30-2013, 06:32 PM Thread Starter
To answer some questions ,
Don't know what brand the pipes are but they are straight thru mufflers, not smooth inside, but not restrictive at all.
I have no info on wether or not the previous owner did any fueling upgrades when he changed mufflers/pipes.
I agree it is running lean and it does pop on decelleration but I have heard worse.
Seems to run ok now that we tightened up clamps but before that it ran a little rougher. Ran it about 50 miles today without any problems.
I think it just needs tuned and fuel added to the tune to make it right.
Bad part is now it needs new or at least different pipes . (Look like shit)
2001 V92C(sold)
2004 Kingpin
post #9 of 16 (permalink) Old 03-30-2013, 06:50 PM
If funds are an issue you can get thrm ceramic coated...
post #10 of 16 (permalink) Old 03-30-2013, 06:55 PM Thread Starter
Yes , funds are always an issue it seems. Lol
I also thought they may be able to be re-chromed but I really have no idea about such things.
I assume ceramic coating would be black?
2001 V92C(sold)
2004 Kingpin
