Drive Belt V92 SC - Victory Forums - Victory Motorcycle Forum
 6Likes
post #1 of 41 (permalink) Old 12-13-2017, 12:50 PM Thread Starter
Default Drive Belt V92 SC
Hi im in New Zealand...i will need a new belt soon..stone damage..does anyone know of aftermarket belts that suit..i was told some harley belts might fit..any advice would be apreciated...Thanks
Kiwi Rider is offline
post #2 of 41 (permalink) Old 12-14-2017, 02:02 PM
never heard of any HD belt fitting a stock Vic. you should count the teeth and measure the width so you know your getting the right one
post #3 of 41 (permalink) Old 12-14-2017, 05:31 PM
BP6666VR's Avatar
Read this thread, and count the teeth on your belt
https://www.victoryforums.com/showthread.php?t=10015
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #4 of 41 (permalink) Old 12-14-2017, 09:37 PM
Motorbikerx's Avatar
Friggin stones!...where exactly is the hole?
If its on the edge youre in trouble.
But central is fine..I ran 60,000kms with a central hole and only changed to a new belt cos I worked the engine over somewhat and had it in the shelf.
Remove the stone of course.
Drive belts are tough
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #5 of 41 (permalink) Old 12-18-2017, 01:05 AM Thread Starter
Ok...the oem offical "victory" belt is 135 teeth product code (3211085) it is 1.5 inches wide...i have found a 135 tooth " gates" belt that is also 1.5 inches wide product code PC -135 1 1/2...they are a harley belt...and around half the price..can you guys add some feed back im in New Zealand and i would buy one on e-bay but id hate to end up with a useless belt..a few 2nd opinions would be great before i commit...thanks.
BP6666VR likes this.
post #6 of 41 (permalink) Old 12-18-2017, 01:56 AM
BP6666VR's Avatar
Do you have a web link to that site? If that HD belt is rated for a higher power then the victory engine can produce then you are safe....
BP6666VR is offline
post #7 of 41 (permalink) Old 12-18-2017, 02:08 AM Thread Starter
I just cross referenced belt width and number of teeth...and up came the gates belt..im not overly sure...seems the gates belt suits a lot of harleys tho
post #8 of 41 (permalink) Old 12-18-2017, 02:52 AM
BP6666VR's Avatar
I can't find the rated power for the belt,
https://www.getlowered.com/drag-spec...th-for-harley/
https://www.jpcycles.com/product/600...nal-drive-belt
BP6666VR is offline
post #9 of 41 (permalink) Old 12-18-2017, 04:02 AM Thread Starter
That 2nd link alows you to select your motorcycle ...interesting that according to the result it does not fit the victorys...any thoughts on why that might be?..the specs seem identical?
post #10 of 41 (permalink) Old 12-18-2017, 04:36 AM
BP6666VR's Avatar
Ya that is standard for JPcycles, so many times I had the same problem on that website....
BP6666VR is offline
