fuel pump wont stay running - Victory Forums - Victory Motorcycle Forum
 1Likes
  • 1 Post By BP6666VR
post #1 of 9 (permalink) Old 03-17-2018, 08:53 PM Thread Starter
Unhappy fuel pump wont stay running
Hi all, its been a while since i posted anything, i have a 2000 V92C that quit running late last year! so i finally got to it today to check it out. i thought at first my pump went out. first thing i did was check the fuse and relay, everything checked out good. i then took the fuel pump out and checked it, it worked! so i start to dig around. i noticed that when i first key on the fuel pump does turn on but does not stay running! Has anyone had this issue before? Does anyone have a wiring circuit diagram?
kwasiak is offline
post #2 of 9 (permalink) Old 03-17-2018, 09:02 PM
VicVisionBulldog's Avatar
It sounds like the pump is working fine but maybe I need more details.
When you turn on your key and flip the switch to run you'll hear the pump prime the system but it should only be heard for a few seconds. After the system is primed the pump is not heard any more.
Is this what is happening?
VVB
13 Vision Tour - PCV, Top Filter, Stage 1 Pipes, TW @ +4, Metz 888s
VicVisionBulldog is offline
post #3 of 9 (permalink) Old 03-17-2018, 09:18 PM Thread Starter
That is correct, i also have a fuel gauge on it but i have no pressure on the system.
kwasiak is offline
post #4 of 9 (permalink) Old 03-17-2018, 10:10 PM
BP6666VR's Avatar
So i read somewere that you can hire fuel pressure gauges to connect to the vic hoses under the tank to check the fuel pressure ...
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #5 of 9 (permalink) Old 03-18-2018, 01:10 AM
Sounds like the pump is bad. Are you aware of the aftermarket pumps and filters available at the link below? They don't have the 2000 listed but you might be able to retrofit it.
https://www.highflowfuel.com/i-21963...2003-2018.html
post #6 of 9 (permalink) Old 03-18-2018, 09:17 AM
Tony.v's Avatar
Default B
Could it be a plugged fuel filter?
2017 Victory Vision Gloss black
1996 Kawasaki Voyager XII (sold)
1981 Kawasaki GPz550 (sold)
My YouTube channel with some great ride videos https://www.youtube.com/channel/UCZQ...zKe8NanTYPyiiA
Tony.v is offline
post #7 of 9 (permalink) Old 03-18-2018, 12:10 PM
The Vic Shop can rebuild your pump.
Contact - The Vic Shop
ok now watch video and do what Rylan tells you
post #8 of 9 (permalink) Old 03-18-2018, 09:11 PM
BP6666VR's Avatar
Nobody remembers how they talked about the disconnecting fuel hose into a fuel pressure gauge and read the value ?
Before ordering all kinds of stuff ?
Lets say this would happen to me, then i have no other option then to order the aftermarket
Fuel Pump
Fuel Regulator thingie
Fuel Filter
Then try again .... But you guys in America can hire tools, and that includes this vic connection fuel pressure gauge .....
Just a thought ... I bought a oil pressure gauge from aliexpress, and the FUEL TANK CONNECTION is standart (see picture 11.8 )..... so can rig to a connection from TANK to OIL gauge
PS note, the fuel gauge connection bihind your cheese wedge is IMPOSSIBLE to buy ... It is a special size ... Vic only crap ...
BP6666VR is offline
post #9 of 9 (permalink) Old 03-18-2018, 09:14 PM
BP6666VR's Avatar
Hey @BBob thats the fuel filter you gave me as a present .... Super thanks .... And your belt is always in my motorcycle jeans ...
BBob likes this.
BP6666VR is offline
