Fork oil type/volume - Page 3 - Victory Forums - Victory Motorcycle Forum
 3Likes
post #21 of 22 (permalink) Old 02-28-2019, 07:14 AM
jzelina's Avatar
Thanks for the replies. I'm not real sure on the local dealer on parts. What I've read taking the forks apart to change the seals will possibly damage the bushings. I don't thinks the forks are bad but I'd have to get so far then have to wait for parts. I'm new to this if you haven't guessed. So the more I can learn before I get into this I'm sure the better it will go.
jzelina is offline
post #22 of 22 (permalink) Old 02-28-2019, 08:04 AM
BP6666VR's Avatar
When i did my jackpot i had blown seals, so i had to do a rebuild, but if the forks are not leaking then i will do the following,
1. As per video drain oil from top-cap only
2. Fill half oil and pump, and drain again
3. Fill as per speck but measure the mm from top of forks also
4. Install top-cap and RIDE AGAIN
Andre using TaPaTaLk
RICZ likes this.
Cross Country Tour 2014 [B]
BP6666VR is offline
