Fork oil type/volume - Victory Forums - Victory Motorcycle Forum
 3Likes
post #1 of 22 (permalink) Old 01-15-2019, 02:11 PM Thread Starter
Default Fork oil type/volume
Hi all...im replacing the fork seals on my v92sc due to a leak one side...i didnt think to save the oil from the good side for a volume reference...so need to know the type and capacity...thanks 😎
Kiwi Rider is offline
post #2 of 22 (permalink) Old 01-15-2019, 05:39 PM
BP6666VR's Avatar
Hello, did you download the manual ? It is all stated in there
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 22 (permalink) Old 01-15-2019, 06:01 PM Thread Starter
Thanks yes found it...strange thing is i measured all the fork oil and got 1250mils figured i lost say 50mils..so thats 650mils per fork...but the volume stated in the manual says 600mils...also still unsure of oil weight as it says 7.5/10/15/20...take your pic i guess ? Any recommendations?
post #4 of 22 (permalink) Old 01-15-2019, 10:18 PM
If you respect your teeth, go with a lower viscosity. I use Bel Ray synthetic 5W and its still pretty firm.
post #5 of 22 (permalink) Old 01-15-2019, 10:52 PM
BP6666VR's Avatar
I used OHLINS, not sure if i used the right one, but it worked nice for me ...
BP6666VR is offline
post #6 of 22 (permalink) Old 01-16-2019, 12:55 PM Thread Starter
Hi again...what weight ohlins did you use?
post #7 of 22 (permalink) Old 01-16-2019, 06:35 PM
BP6666VR's Avatar
It a bit different with Fork fuid, i think it is 7.5 weight, the same as original
On the picture it says OHLINS No.5 only ...
BP6666VR is offline
post #8 of 22 (permalink) Old 01-16-2019, 06:53 PM
Maybe we are looking at different pics but the one I see says No. 10.
post #9 of 22 (permalink) Old 01-16-2019, 07:08 PM
Do some homework to pick what's best for you if you are moving from what the bike manufacturer recommends. A problem with fork oil is there is no universal standard and the weight numbers are not transferable between the different oil producers. There are some big differences in the flow and therefore the responses you will get.
This is only one reference. Take a look and you'll find more.
https://transmoto.com.au/comparative-oil-weights-table/
BBob and BP6666VR like this.
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
post #10 of 22 (permalink) Old 01-16-2019, 08:09 PM
BP6666VR's Avatar
Ohhhh sorry, i just went online OHLINS and found No.5 .... ha ha
Yes the one i used in my front fork before is No.10 as per picture
BP6666VR is offline
