No Fuel to Rear Cylinder - '02 V92C - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 05-26-2019, 10:26 AM Thread Starter
Default No Fuel to Rear Cylinder - '02 V92C
Hi all,
My rear cylinder isn't firing. I have spark and 160psi on the cylinder. I replaced the spark plugs and the rear one keeps getting black and isn't wet. The injectors look clean and I swapped the front and the rear ones and the issue didn't change. I even pulled off the Dynojet Power Commander. I can't figure out why I am not getting fuel to the cylinder. What should my next step be?
hypeshipe is offline
post #2 of 3 (permalink) Old 05-26-2019, 10:34 AM
The computer controls fuel to the injectors I think so maybe there's a problem there or in the signal to that injector. Then there's the TPS and TPS reset to check or try. Howabout the plug wires. Are you able to swap them or try any plug wire that will fit for testing purposes.
BBob is online now
post #3 of 3 (permalink) Old 05-26-2019, 12:41 PM
BP6666VR's Avatar
Change your battery
Unplug your injectors,
Pug them back in
Start your bike ....
I had this code before ....
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
02 V92C Mustang Seat oldriverrat Motorcycle Parts For Sale / Wanted 3 07-16-2015 12:03 PM
WTB: Crashbars/Hiway bars for an '02 V92C DaveTV Motorcycle Parts For Sale / Wanted 4 03-29-2013 12:48 PM
02 V92C Tranny noise Uncle Frank Victory V92C 2 06-21-2012 05:52 PM
02 V92C Deluxe Lowering Links Uncle Frank Victory Tech and Performance Section 2 05-24-2011 11:32 PM
02 V92C Deluxe Idle Adjustment Uncle Frank Victory Tech and Performance Section 1 03-13-2011 10:25 AM
