v92 engine swap, kevin x - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 09-29-2010, 10:22 PM Thread Starter
Default v92 engine swap, kevin x
ive got a 1999 victory v92c with transmission problems. jumps out of 4th gear. i tear it down and it has bent forks and rails and dog gears are worn. parts are too expensive and the trans has design flaws. my question is: will a 2001 engine bolt on? up to what year will bolt on? what would i need for a swap? computer, sensors? the bike means alot to me and i want to put a reliable motor on it. any info on the subject of and engine swap would be greatly appreciated.
1madvic is offline
post #2 of 7 (permalink) Old 09-30-2010, 06:12 AM
kevinx's Avatar
The 01 is a direct bolt in, and with very little work any 92" up through 06 will bolt in
kevinx is offline
post #3 of 7 (permalink) Old 09-30-2010, 10:32 PM Thread Starter
is there any where i can double check the id numbers on the engine unit so i know i dont get another 99-00 piece of junk. if anyone has an engine unit to sell, email [email protected]
drew
1madvic is offline
post #4 of 7 (permalink) Old 10-01-2010, 06:02 AM
kevinx's Avatar
If the motor looks the same, and has a speed sensor mounted in the top of the case behind the rear cyl. It is a 99-00. Though the tranny may have been updated if the motor also has a speed sensor "looking" at the drive sprocket.
The 99 is the only year that had gloss black for the motor. Starting in 00 the engines were satin, textured finish
To put in a later Freedom 92" motor 02-06. All you need to do is to swap the crank trigger wheel, and voltage regulator. The rest will work as is
kevinx is offline
post #5 of 7 (permalink) Old 10-05-2010, 12:14 PM Thread Starter
Default kevinx v92 engine swap
i found a 2002, v92 for my 99 swap. can i use the crank trigger wheel and voltage regulator off my 99 to complete the swap?
1madvic is offline
post #6 of 7 (permalink) Old 10-05-2010, 12:54 PM Thread Starter
where is the crank trigger wheel located. do you have to seperate the cases. i cant find it on the microfiche.
1madvic is offline
post #7 of 7 (permalink) Old 10-05-2010, 01:22 PM Thread Starter
is the crank trigger wheel the flywheel exciter ring?
1madvic is offline
