engine swap kevin x - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 10-05-2010, 01:58 PM Thread Starter
Default engine swap kevin x
i found a 2002 engine unit but i have a couple questions. is the flywheel exciter ring the crank trigger wheel? do i replace that with my 99 ring and the sensor that bolts to the case to complete the swap? what about the voltage regulator? do i just use the 99. thank you for your help its been much appreciated
1madvic is offline
post #2 of 3 (permalink) Old 10-05-2010, 06:15 PM
kevinx's Avatar
Yes it is the crank trigger ring, and you need to use the one on your 99
You will need a 02 and up voltage regulator
kevinx is offline
post #3 of 3 (permalink) Old 10-06-2010, 07:13 PM Thread Starter
thank you for your help. ill let you know how it turns out. cant wait to ride even though it is cold now
1madvic is offline
