Clock problem - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 07-12-2013, 10:56 PM Thread Starter
Ghost_Rider's Avatar
Default Clock problem
So every time I turn my bike off, the clock resets itself back to 12:00. I know the battery is fine, I checked the static voltage today and it read 13.22 volts. It's not hurting anything, just a bit of a nuisance. Any ideas?
2003 V92C
Wrapped RPW Slash pipes
K&N air filter
Stebel Nautilus
Viking saddlebags
16" apes
Ghost_Rider is offline
post #2 of 4 (permalink) Old 07-13-2013, 06:51 AM
handyhoward's Avatar
Is it the "clock" you're looking at or the trip timer?
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
handyhoward is offline
post #3 of 4 (permalink) Old 07-13-2013, 02:39 PM
Tims_04V92TC's Avatar
The speedo has a batt backup that eventually looses contact which can lead to the speedo resetting mileage as well as time. If your odometer is NOT resetting when the time does, I would pull the connector in the headlight bucket, spray with alcohol or contact cleaner, then a little dab of dielectric grease and reconnect. Also chEck your terminals that they're clean and retighten using star washers. That's a starting point.
Ti
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #4 of 4 (permalink) Old 07-13-2013, 03:25 PM Thread Starter
It's the clock I'm looking at, it doesn't have a trip timer. The odometer has not reset, so I will try that Tim. Thanks
2003 V92C
K&N air filter
Stebel Nautilus
Viking saddlebags
16" apes
