99 gas tank - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 12-01-2010, 11:59 AM Thread Starter
Default 99 gas tank
I need a gas tank for my crashed 99 V92C. does anyone know where I can find one? Please call me at that is my cell.
Thank you
Daveh221 is offline
post #2 of 6 (permalink) Old 12-01-2010, 12:09 PM
CrossRoads's Avatar
Daveh221,
You might want to edit your post and remove your phone number from it. Let others contact you through the forum's private messaging, or by replying to your post.
Unless, of course, you're really lonely, and would like a wave of telemarketers keeping you company.
CrossRoads is offline
post #3 of 6 (permalink) Old 12-01-2010, 12:15 PM
The Diamond
diamondrmp's Avatar
Definitely take your phone number off please.
I see those tanks on Ebay all the time.
diamondrmp is offline
post #4 of 6 (permalink) Old 12-01-2010, 09:36 PM
Default RE: 99 Tank
I have a 2000/2001 V92C tank & fender set with the factory black with flames paint. New old stock. Never mounted and never had gas in the tank. I have them listed in the classifieds.section of this forum. Posted on 09-22-10.
51.50 is offline
post #5 of 6 (permalink) Old 12-02-2010, 03:00 PM Thread Starter
Default 99 gas tank
The 99 gas tanks are a one year make only. In 2000 Victory changed the bolt tie down with a flange that you had to screw the tank down threw the top. The 99 had studs welded under the tank. You ran the two nuts up under the frame up to the welded flange.I'm looking for the 99 gas tank. All the fenders were the same, they would just bolt right up and away you go. I've got the 99 three step paint so all I need is a front and rear fender.
Email is [email protected] thank you.
BURN-RUBBER!!!
Daveh221 is offline
post #6 of 6 (permalink) Old 12-06-2010, 02:05 PM
CrossRoads's Avatar
A fellow forum member is selling a '99 gas tank:
https://www.victoryforums.com/showthread.php?t=3521. I guess you're in luck!
