Dimple aftermarket oil plug - Victory Forums - Victory Motorcycle Forum
post #1 of 1 (permalink) Old 08-19-2013, 09:24 PM Thread Starter
Kyleh1214's Avatar
Default Dimple aftermarket oil plug
When I bought my Victory, the previous owner had stripped out the allen hole. Now I have to use vise grips to get the plug out. I saw replacement plugs that are low profile like the stock plug, but the problem is stripping them out again. The solution I found is Dimple Products oil plugs. They have a full size socket head. Granted they do sit lower to the ground than the stock plug, which makes them susceptible to scraping. They are a bit expensive at $34.95 but I'm sure it will be worth it in the long run.
http://www.drainplugmagnets.com/victorymotorcycles.php
1974 Honda CR250 (2003-2006)
1984 Kawasaki GPz900 (2009-2011)
2004 Suzuki Volusia (2012-2013)
2004 Victory V92TC (2013-20##)
Kyleh1214 is offline
