Won't start in gear, check engine light on. - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 10-29-2013, 07:51 PM Thread Starter
George D's Avatar
Default Won't start in gear, check engine light on.
Hi All, Bit of a strange problem started today. Normally I click the key, turn the fuel on, squeeze the clutch and fire up the bike. Today I go to start it after a short ride and nothing happens when I hit the starter button. I click it into neutral and it starts. This happened a few times. As I was coming home from work, the check engine light starts flashing. How can I check what is causing it? I tried searching the forum for 45 minutes and gave up.
Bike is a 2002 and has 45,000 miles on it.
George D is offline
post #2 of 14 (permalink) Old 10-29-2013, 07:53 PM
LILMAGS500's Avatar
What model is it ?
LILMAGS500 is offline
post #3 of 14 (permalink) Old 10-29-2013, 07:58 PM
LILMAGS500's Avatar
The not starting sounds like a switch issue , such as a neutral safety switch , I wouldn't be surprised if the two symptoms were NOT related , such as a coincidence .... See it all the time in automobiles ....
post #4 of 14 (permalink) Old 10-29-2013, 08:20 PM Thread Starter
George D's Avatar
It's an 02 V92TC, I had no idea these even had a neutral safety switch. I guess I can trace it back and check. Anyone know the procedure to find out what the check engine code is?
George D is offline
post #5 of 14 (permalink) Old 10-29-2013, 08:45 PM
ndabunka's Avatar
Sounds like battery issues. Either connections or going down. Have you had it checked lately?
It's not just any victory.... It's MY Victory!
2011 Victory Ness Cross Country #120
Ness Thunderheaders
Ness Knurled Highway Pegs/KwelMetal Brackets
Ness Radius laydown license
Chrome CAM Tension Covers
Red Engine Bolts
Madstad System
DIY Garage Door Opener
Victory Chrome Saddle Bag Lid Rails
Küryakyn Upper Fork Shrouds
Küryakyn Lower Fork Covers
Power Commander V Tuner
Power Commander AT-300
Hertz HCX 165s Speakers
JL Audio HX280/4 Bridged 140w
ndabunka is offline
post #6 of 14 (permalink) Old 10-29-2013, 09:42 PM Thread Starter
George D's Avatar
Just tightened the positive cable, was a little loose. Fired it up, no "Ch Eng" but it still won't start in gear with the clutch in.
Just found my manual. Looks like I need to do some testing.
"Starter motor will not turn when the
transmission is in gear with the
clutch pulled in, but will turn when
the transmission is in neutral.
Clutch Safety Switch Circuit is not
functioning correctly.
Test 2C"
CLUTCH SWITCH CIRCUIT: Test 2C
The symptom of a faulty clutch switch circuit is:
S Starter motor will not operate when
transmission is in gear with the clutch lever
pulled in. Starter will turn when transmission
is in neutral.
NOTE: The clutch switchmakes an audible click at the
beginning of the clutch lever travel. This is a good
indication that the clutch switch is working but using an
ohmmeter is the best test. A faulty switch will set acode
in the ECM, but will not set a CH ENG light.
1. Place the transmission in neutral.
2. Remove left side cover.
3. Disconnect switch connector at starter relay
(carefully pull lock tab (A) down, and push
connector away from relay to diconnect.)
4. Set DMM to Ohms (��).
5. Connect red (+) lead ofDMMto the blue/yellow wire
(B) of starter relay wiring harness connector as
shown at right, using a test probe from Victory
Connector Test Kit PV 43526.
6. Connect DMM black lead to battery negative post.
7. Operate clutch lever while observingmeter display.
8. Pull in clutch lever. The meter should display
continuity to ground or very low resistance (less
than 1 ohm).
9. Release clutch lever, meter should display infinity
(O.L. on Fluket 73).
10. If clutch switch does not test as described inspect
clutch switch, clutch switch wiring or mounting of
switch to clutch lever for fault as described below.
11. Disconnect clutch switch wiring connector.
12. Connect ohmmeter across terminals of clutch
switch. Test for continuity when clutch lever is
pulled toward handlebar. Test for open circuit when
clutch lever is released.
13. If the clutch switch now operates correctly, the
wiring between this point and the previous test point
is at fault and must be corrected.
14. If the clutch switch still does not operate correctly,
inspect the mounting of the switch.
15. If the switch is mounted correctly and physically
operates but does not open and close electrically.
Replace the clutch switch and test
2002 V92 TC
George D is offline
post #7 of 14 (permalink) Old 10-30-2013, 07:12 AM
ByteN2it's Avatar
There's a micro switch that is engaged by the clutch lever for starting in gear-same as the one on the brake lever that activates the brake lights. Sometimes they get displaced and sometimes they fail-look up under the lever and you'll find it. If you have to replace the only source I've found is Victory and they ain't cheap.
http://www.cycle-parts.com/Products/427650-4110257.aspx
ByteN2it is offline
post #8 of 14 (permalink) Old 10-30-2013, 10:33 AM Thread Starter
George D's Avatar
I actually checked it last night. I have a lot of free play in my clutch lever, to the point where that switch hasn't been engaged in forever. I did see the name and model number of the switch and it looks like I can get it from the manufacturer for arout $23.
2002 V92 TC
George D is offline
post #9 of 14 (permalink) Old 11-08-2013, 11:46 AM
Ghost_Rider's Avatar
Where did you find it for $23? I need a switch too, called the dealer, they want $65 for that little thing!
2003 V92C
Wrapped RPW Slash pipes
K&N air filter
Stebel Nautilus
Viking saddlebags
16" apes
Ghost_Rider is offline
post #10 of 14 (permalink) Old 11-08-2013, 12:01 PM Thread Starter
George D's Avatar
http://www.marquardt-shop.com/produc...ches/1022.html
Haven't purchased it yet as I want to remove the old one and make sure its the same.
EDIT- Ugh, looks like $25 minimum shipping.
2002 V92 TC
George D is offline
