oil cooler - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 12-12-2013, 01:20 PM Thread Starter
Dann's Avatar
Default oil cooler
Has anybody replaced that big ol fugly oil cooler with something that
looks and performs good. every time i look at thing i want to rip it off the bike. Gotta be something better out there.
Cedar Lake Indiana
V92c Standard Cruiser
Dann is offline
post #2 of 14 (permalink) Old 12-12-2013, 08:29 PM
Speeddemon3579's Avatar
There have been some replaced. I've seen the photos. I'll try to find them.
2000 V92SC
Rock Island,TN
If I can't buy it, I make it.
Just Getting Started
Speeddemon3579 is offline
post #3 of 14 (permalink) Old 12-12-2013, 08:44 PM
This was by another rider. Do a search for it. Looks good. It is the Pro One oil cooler. Wasn't installed for benefit. Steel frame bikes have the triangular oil cooler tucked within the frame, down low. The non-steel frames have the rectangular cooler mounted in front of the frame, up high. Ground pounders are too phat to work with the stock oil cooler on the steel frames so you have to relocate the cooler. No need to relocate on the non-steel frames.
I have no clue on the specs if the Pro One is better than stock and I don't care. It adds to the unique look of the bike.
Check the Pro One site for information on performance.
http://www.pro-one.com/Oil_Coolers_s/86.htm
2000 V92SC
Rock Island,TN
post #4 of 14 (permalink) Old 12-14-2013, 04:43 PM Thread Starter
Dann's Avatar
Thanks for the reply's. I did see that billet one but a little pricy for my wallet. Looking at this one but not sure it will cool good enough.
Cedar Lake Indiana
Dann is offline
post #5 of 14 (permalink) Old 12-14-2013, 05:28 PM
Do some research Vic found out the early models had to big a cooler so they went to a smaller one. You find the year they changed I'll bet you could find one on ebay and it might just bolt right up if it comes with the lines
post #6 of 14 (permalink) Old 12-14-2013, 08:22 PM
dope_man_21's Avatar
Installed one of those (Milwaukee twins) on my HD (FXDSE) ended up taking it off because with those bikes the high heat was an issue, but the engine would still go into "parade mode" (turning the rear cylinder into an air pump) to cool off when idling so I don't know if it would work on the Victories, but did not change any thing on my Harley.
$20,000 and 3000 miles DO NOT make you a biker
2013 Victory HighBall
Patriot Guard #156315
dope_man_21 is offline
post #7 of 14 (permalink) Old 12-15-2013, 06:51 AM
Loach's Avatar
You can go on eBay like I did and get an oil cooler for a V92TC from one of the motorcycle salvage dealers! You will need to get the mounting bracket and oil lines as well but it will bolt right on! It looks much better then that huge "radiator"! The only issue you'll have is you will need to convert the oil line attachments at the engine to "AN" fittings! The early V92C and SC engines used "AN" (Army/Navy aircraft standard) fittings for the oil lines which are much better and look much nicer than the change to the automotive fittings on the later V92 Freedom engine that is installed in the V92TC. Conquest Customs makes an AN oil line conversion kit for the later Freedom engines that comes with new oil lines that will make the installation easy! You just won't need the fitting adapter out of the kit for your engine! Good luck!
1999 V92C
2012 XCT
Stroudsburg, PA. U.S.A.
"Life is what YOU make it!"
Loach is offline
post #8 of 14 (permalink) Old 01-07-2014, 09:44 PM
I may go with these. Wish they were black though.
2000 V92SC
Rock Island,TN
post #9 of 14 (permalink) Old 01-08-2014, 12:08 AM Thread Starter
Dann's Avatar
I decided to pass on the Milwaukee Twin one. May go with the later model Victory smaller one. speeddemon did you forget to add a link or
picture?
Cedar Lake Indiana
Dann is offline
post #10 of 14 (permalink) Old 01-08-2014, 05:48 AM
Thought it would copy pic you had posted. Oops
2000 V92SC
Rock Island,TN
