Brake Light - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 08-07-2011, 09:00 AM Thread Starter
Angry Brake Light
99 V92 C, Brake light doesn't work with rear brake, only front. I suspect pressure switch. Where is this switch located? I saw the drawings on the parts Fiche. Is this a special switch? could an oil sending unit switch be used?
Thanks
Mark
markV92C is offline
post #2 of 13 (permalink) Old 08-07-2011, 09:30 AM
NOEMTZ's Avatar
Thanks
Mark
Most brake pressure switches only cost about $10 ....not sure if yours is any different. Follow brake line from caliper forward and your bound to run into it. Only has a two wire plug attached to it.
www.noemtz.com
NOEMTZ is offline
post #3 of 13 (permalink) Old 08-07-2011, 10:11 AM
Goatlocker95's Avatar
Here is the picture showing where the switch is located
The switch is item #22 which originally had part number 4110238 which was later replaced by part number 4010372.
Motorcycle Monster lists it for $15.70
Not sure if the oil sending unit would work but unless you have a spare sending unit why? If you do have a spare you could try it to see what happens but that could lead to other problems.
2014 Indian Chieftain
Goatlocker95 is offline
post #4 of 13 (permalink) Old 08-07-2011, 05:19 PM
The Diamond
diamondrmp's Avatar
Check to make sure the plug hasn't come loose. If its tight clean it and plug it back in. Many times that's all there is or a blown bulb or fuse.
diamondrmp is offline
post #5 of 13 (permalink) Old 08-09-2011, 08:09 PM Thread Starter
Exclamation Thanks for everyone's help
I found the switch and cleaned the contacts on connectors, still no brake light. I jumped across the 2 wires and the brake light worked. Bad switch........my question, how much fluid will be lost when changing the switch and will I need to bleed the brakes after switch replacement?
99 V92C
Thanks for everyone's help.............
Mark
markV92C is offline
post #6 of 13 (permalink) Old 08-09-2011, 08:11 PM
kevinx's Avatar
Not much fluid loss, but you will need to bleed it
kevinx is offline
post #7 of 13 (permalink) Old 10-24-2011, 07:51 AM
Mark, I'm just hitting this same issue and was wondering if the switch and bleed was all it took.
2000 V92C Black
V92PS2000 is offline
post #8 of 13 (permalink) Old 10-24-2011, 08:18 PM Thread Starter
Default Brake light switch
I have yet to replace it, I did buy the switch, right around $20.00. I did verify the switch was bad by jumping across the 2 terminals that plug into the switch, with the ignition on, the brake light came on. I figure this is a small winter project. The switch is located on caliper side , right under the frame.Follow the brake line from the caliper forward. Don't forget the DOT 4 brake fluid.
Good luck
Mark
markV92C is offline
post #9 of 13 (permalink) Old 02-15-2012, 03:42 PM
Mark, I still have replaced mine yet, but need to before my annual inspection is due. Have you gotten around to yours and how difficult was it?
2000 V92C Black
post #10 of 13 (permalink) Old 02-15-2012, 05:03 PM
karmobRob's Avatar
If you apply gentle pressure on the pedal as you change the switch, no air will enter the system. You may spill a fraction, have a catch-can under and top up reservoir.
ROUTE 6 MC TASMAN NEW ZEALAND
2002 V92C CUSTOM
2012 HIGHBALL [ Sold ]
karmobRob is offline
