Engine dies at idle - Victory Forums - Victory Motorcycle Forum
post #1 of 24 (permalink) Old 07-13-2014, 05:04 PM Thread Starter
Dann's Avatar
Default Engine dies at idle
My bike has started to die out when i pull up to a light or just about any time I'm stopping. Say I'm pulling up to a light or stop sign i pull
the clutch in to shift to 1st gear and the engine just dies. Before you
ask I'm not blipping the throttle. So my thoughts are maybe a vacuum leak? It don't do it all the time but at least 1 to 3 times when I'm out riding.
Other than that the bike runs great. any ideas? anyone ever have this problem?
Cedar Lake Indiana
V92c Standard Cruiser
Dann is offline
post #2 of 24 (permalink) Old 07-13-2014, 06:16 PM
pull right cheese wedge and with motor running spray some WD-40 at the FI rubber boots. If idle revs up or bike dies you have air leak.
You did check battery bolts with a wrench to see if there tight.
You'll have to write Rylan at The Vic Shop and ask how to check fuel pump pressure. It should be 50psi no less
post #3 of 24 (permalink) Old 07-13-2014, 06:18 PM
found this and he does have fuel pump
http://minneapolis.craigslist.org/an...555381531.html
post #4 of 24 (permalink) Old 07-13-2014, 08:19 PM Thread Starter
Dann's Avatar
No i haven't checked anything yet. I was out riding all day and when i got home i had some errands to run. I will check all that tomorrow.
As far as the fuel pump go's, it don't make sense to me that it would be bad. I was running 70 to 80 today and it ran great. But you never know, i will check that when i get hold of a pressure gauge. I came across a post a while back about some rubber plugs or caps on the throttle body that go's bad also. I really think it's a vacuum issue.
( I hope ) that would be a easy fix.
Also Thanks for that link on Craigslist. That may come in handy.
Cedar Lake Indiana
Dann is offline
post #5 of 24 (permalink) Old 07-14-2014, 07:29 AM
fuel pump issue possibly. like vj said. my sons kp had this issue, I guess its common. Lloyd sells a repair kit I believe. its not that the pump isn't working, its that the system doesn't maintain proper psi.
for sale
07 kingpin
2 into 1 RPW Thor
S&S intake
Lloydz vfc III
woc fairing
14 anti freeze xc
116 ci
vm1 cams
ported heads
big honker exhaust
lloydz intake
warrior1 is offline
post #6 of 24 (permalink) Old 07-14-2014, 08:04 AM
Rebel Biker's Avatar
Also check for carbon build up around the throttle body plate. Carbon build up is normal and should be cleaned from time to time. If you see black carbon build up all around the throttle plate, spray a little carb cleaner on it to loosen it up, scrub with a brass wire brush then wipe clean with a shop rag.
https://www.youtube.com/watch?v=KOZw...ature=youtu.be
2014 Victory Cross Country Tour - Two Tone Sonic Blue and Silver
PCV 6,500 rev limit, Lloydz VM1-DR Cams, Lloydz Hi Flow Filter, Atom Bomb exhaust, Lloydz ATS +4, Lloydz 1/4 Throttle. 111 HP / 116 TQ
2012 Victory Kingpin - Traded in on XCT
2007 Honda Shadow Aero 750 - Traded in on KP
Rebel Biker is offline
post #7 of 24 (permalink) Old 07-14-2014, 12:39 PM Thread Starter
Dann's Avatar
Thanks for the reply's. looks like i have some work to do. I cleaned the
throttle body 2 years ago and haven't put that many miles on sense
then. one thing i will do that i haven't done sense i have owned the bike is changing the fuel filter. I did change the inlet filters last year.
Cedar Lake Indiana
Dann is offline
post #8 of 24 (permalink) Old 07-15-2014, 04:43 PM
rojo154's Avatar
Yes, there are 2 vacuum ports with rubber caps on them that dry rot. I did not see the year of your bike but being a v92 good chance these are bad. I would also suggest cleaning the throttle bodies and check the rubber goose neck that connects the tb to the motor. these can dry rot too. I replaced mine last year as it was showing signs of cracking. Wasn't leaking yet but was just a matter of time especially our bikes are 10 years old ..or better.
rojo154 is offline
post #9 of 24 (permalink) Old 07-15-2014, 09:37 PM Thread Starter
Dann's Avatar
I think i will pull the tank when i get time. Yesterday i sprayed some carb Cleaner up to the throttle body area and it made no difference
in the idle. Very hard to see anything up in there. Funny thing is it will sit and idle all day, it's when it when it comes down from a higher rpm
when it dies. (sometimes) I will be sure to check them rubber boots and caps when i pull the tank.
Thanks
Cedar Lake Indiana
Dann is offline
post #10 of 24 (permalink) Old 07-16-2014, 11:09 AM
rojo154's Avatar
Originally Posted by Dann View Post
.. Funny thing is it will sit and idle all day, it's when it when it comes down from a higher rpm
Thanks
.. Thats making me think the vacuum leak may be the culprit as vacuum will increase on decel. If you pull the right side cheese wedge you should be able to find the rubber vacuum caps without pulling the tank. Also be sure to spray around the fuel injectors to check for leaks while the bike is running as the o-rings may be faulty.
rojo154 is offline
