Contemplating an engine swap - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 07-29-2014, 06:27 PM Thread Starter
Submariner's Avatar
Default Contemplating an engine swap
Do I need it.. Probably not but with 65k miles on my 2000 V92SC and not knowing how the person prior to the guy I bought it off maintained it I figure a spare motor all ready to go can't be a bad thing. My thinking would be to have a mild build above stock and keep it dependable but I have no clue what engine to look for. I seem to recall reading here only a V92 will bolt up but now can't find that thread. Anyone know what year/size engine I can put in this bike without breaking the bank?
Starting to get the 3rd gear issue which is also nagging at me.
2000 V92SC Bobber built by aishindo3656:
Wiseco fuel controller, leather solo saddle seat, twin headlights, custom hand fabricated bars, rear fender, cluster holder, rear taillight, forward controls (with foot boards) and heel-toe shift, custom exhaust, Jag oil cooler, custom black satin paint.
1981 Honda CB650
2008 Harley Dyna Super Glide
2009 Harley V-Rod Nite Rod Special
1999 Harley Electra Glide
There are only two types of boats in the NAVY Submarines and targets.
Submariner is offline
post #2 of 13 (permalink) Old 07-29-2014, 06:48 PM
Tims_04V92TC's Avatar
Going to be a 99-2001 v92. A freedom v92 will not work due to the tranny changing in 02 then the full freedom v92 in 2002 on. I think your intentions are good but ay wind up with similar issues. First see if you can find the mod mark for the tranny upgrade. Next the one fir the speedo which resolves it resetting to zero miles. Both threads on here, just don't recall specifics.
Problems with 3rd driving your search? What oil you using and give us more info.
You may cut to the chase and call one of the high horse power bubbas on here and get some input and pricing on parts. Intake controller and EPROM with the right pipes and a good Dyno will bring it to life.
Used engines run the risk of cracked front cans if bike was crashed. Read too many bad buys to even think of a used engine from a smash.
Mileage. 60k on a Vic ain't nothin. Hopefully some food fir thought.
Tim
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #3 of 13 (permalink) Old 07-29-2014, 07:00 PM Thread Starter
Submariner's Avatar
Tim
Not sure where to look for the tranny mark but will do a search. Speedo is not resetting. It actually went the other way and went from 65k to 700+k.
Took it to the local Vic dealer and they confirmed all recalls are done.
Hopefully I've just read to many issues and now think I'm having them.
1981 Honda CB650
post #4 of 13 (permalink) Old 07-29-2014, 07:27 PM
If they confirmed the recalls are done that should cover your tranny. Unfortunately oil changes do cause some stiff shifting and 2500 is recommended. See the oil threads for input. I change at 3500. This may be a contributor. What oil you using and mileage. Haven't neared that one on the speedo. 700k?
If you feel good about the motor you can easily pick up some serious HP and torque for a small budgEt. If you already have the controller, I would start on a intake s&s as I don't think the torque tubes will fit. Call lloydz to check. A solid performance exhaust then EPROM and tune. On a bobber? I bet that thing will be a blast. A 2nd motor would not be an option to me on that engine with those miles. But that's me.
If you got specific questions you can probly find the answers here.
IBA Rider
Retired Navy SCPO
Chesapeake Va
post #5 of 13 (permalink) Old 07-30-2014, 06:19 AM Thread Starter
Submariner's Avatar
This link will show the bike and the work done on it:
https://www.victoryforums.com/showthread.php?t=68946
It just had an oil change by the guy who built it and I would guess the oil has under 2k on it. He is meticulous about his bikes so I'm sure he used high quality stuff. I'll look at the oil thread and do another change based on what they recommend.
Yeah 700k on the odometer. When the builder took it apart it showed 61k or so then he pulled it apart, did some work and when he hooked everything back up it read 700k plus.
Thanks for the pointers
1981 Honda CB650
post #6 of 13 (permalink) Old 07-30-2014, 10:25 AM
Nice lookin ride! At first the red was a shocker but grew on me quickly. Swap out that stock air box and I think that Aline will amaze you. In my TC I had the K&N installed and one day just removed the intake screen on the left. Mass a difference enough to buy the beds big sucker. Makes the cans stand out too. Looking forward to what you do to it.
Safe ridin. Tim
IBA Rider
Retired Navy SCPO
Chesapeake Va
post #7 of 13 (permalink) Old 07-30-2014, 11:42 AM
Its going to coast you about 3 grand to do another motor or more.
You should go see Lloydz and talk to him about rebuilding what you have now. It might coast about the same. It would be a solid strong motor after Lloydz did there magic.
Keep in mind you have to find a new motor hope its a good one. The longer a motor sits around the more rust builds up on the inside and you never know if its any good.
Or look to sell what you have and move up to a newer model.
http://www.lloydz.com/
post #8 of 13 (permalink) Old 07-30-2014, 04:59 PM Thread Starter
Submariner's Avatar
Found an 03 V92 with 10k for 1500 plus shipping but sounds like keeping mine is the best option. I live in Maine so NY is a hike but... I'll give him a call and see what he recommends.
1981 Honda CB650
post #9 of 13 (permalink) Old 07-30-2014, 05:01 PM Thread Starter
Submariner's Avatar
Safe ridin. Tim
Tim do you have any close up shots without the airbox? I'd like to see it with your setup
1981 Honda CB650
post #10 of 13 (permalink) Old 07-30-2014, 06:14 PM
Here's best I have while I'm on travel. Looks much cleaner and the extra o2 gives it a nice pep in the step. Would be glad to grab some additional shots or search here for removing stock air box on a 06 or older.
IBA Rider
Retired Navy SCPO
Chesapeake Va
