Turn Signal Problem - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 12-27-2014, 08:06 PM Thread Starter
Default Turn Signal Problem
I was hoping someone could help me? I have a 2007 Jackpot that i just put custom turn signals on. they are not led, and only on the front. They worked when I first hooked up the wires to test them now the Right side only is not working on Hazards or turn signal, the indicator blinks fast also, any ideas?? I know its not the new light cause when I hook it up on the right side the light works fine.
Straydawg
Straydawg is offline
post #2 of 11 (permalink) Old 12-28-2014, 12:17 PM
sorry
the right side signal power wire is different from the left side. Bet you burned up the signal module.
Check fuse just in case but i think you'll find its good. With a meter check for power on the right side if you have none your module is burned up
post #3 of 11 (permalink) Old 12-28-2014, 12:37 PM
Konga63's Avatar
Straydawg
Did you run the diagnostics for the ACM? Run that and see what, if any codes show up. If you have error message(s), see VJ's thought...
sorry
I agree. Sounds like the ACM is fried...
2007 Ness Jackpot
Konga63 is offline
post #4 of 11 (permalink) Old 12-29-2014, 09:18 PM Thread Starter
Not sure how to run diagnostic on ACM?
post #5 of 11 (permalink) Old 12-29-2014, 09:28 PM
second post down will help you all vic the same
http://www.vision-riders.com/bb/foru....asp?tid=12968
post #6 of 11 (permalink) Old 12-30-2014, 12:36 PM Thread Starter
I just noticed that when I traced the front right turn finals wired into the headlight the wires actually switch at the first harness, meaning you would not want to switch them again when I stalling the light. Just an chi cause I see a lot of posts about the wiring being different on the right side
post #7 of 11 (permalink) Old 12-30-2014, 01:40 PM
Konga63's Avatar
... the headlight the wires actually switch at the first harness, meaning you would not want to switch them again when installing the light.
Correct. BluBlk then becomes your ground and Blk your hot wire. PIA for sure.
2007 Ness Jackpot
Konga63 is offline
post #8 of 11 (permalink) Old 12-30-2014, 07:46 PM Thread Starter
When I ran the diagnostic on the ACM the code that kept flashing was 15, that didn't really help because the procedures for that code all checked out fine. The line is just plain dead no juice to it at all so I am thinking I may have to replace the ACM? I just bought the bike too and didn't even put it on the road yet.....damn!!
post #9 of 11 (permalink) Old 12-30-2014, 07:55 PM
Konga63's Avatar
It does look like the ACM is toast. Those units are extremely fragile. I assume you've checked your fuse? If you end up needing to get a new ACM, you can get one from Honda East (a site sponsor) @ 20% discount...every little bit helps, eh?
2007 Ness Jackpot
Konga63 is offline
post #10 of 11 (permalink) Old 12-30-2014, 10:41 PM
NOEMTZ's Avatar
http://www.noemtz.com/purevictoryparts.htm Scroll about half way down the page. OEM..ACM in stock and ready to ship.
www.noemtz.com
NOEMTZ is offline
