Which gear at 60mph? - Victory Forums - Victory Motorcycle Forum
post #1 of 28 (permalink) Old 03-24-2015, 07:58 PM Thread Starter
Default Which gear at 60mph?
Maybe a stupid question but should I be running 5th or 6th at 60mph. Seems like 6th is lugging pretty good at those speeds, maybe it doesn't matter on these bikes though?
upnorthbacon is offline
post #2 of 28 (permalink) Old 03-24-2015, 08:00 PM
OkieHoss's Avatar
not sure what bike you have but my XCT 106 with a 6 speed loves to run 3000 rpm. I run 65mph in 5th. I get the best mpgs there. I dont go into 6th until over 70.
2013 black XCT.
OkieHoss is offline
post #3 of 28 (permalink) Old 03-24-2015, 08:13 PM
I'm usually in sixth at that speed, but that's running solo and on mostly flat roads. If your riding two up, driving into heavy wind, or going up hills, you should be in fifth.
vcc14 is offline
post #4 of 28 (permalink) Old 03-24-2015, 08:40 PM Thread Starter
Sorry I should have mentioned its a stock 2014 jackpot.
post #5 of 28 (permalink) Old 03-24-2015, 08:55 PM
Konga63's Avatar
Vic's run best/smoothest at 2200-2800 RPM (cruising speeds).
2007 Ness Jackpot
Konga63 is offline
post #6 of 28 (permalink) Old 03-24-2015, 10:09 PM
Just like anything, listen to the engine, it'll tell you what it wants and when, and it will want different gears for different situations.. For example, on the long flat straights, or downhill runs, it'll chug happily down a road in 6th at around 2500rpms at 65mph, but my Cross Country really prefers to rev higher going up a hill and power seems more controllable in the twisties between 2800 and 3000rpm so that would be running those kind of speeds a gear lower..
In most situations a bike seems to prefer to run happiest at slightly higher rpms.. A Victory doesn't seem special in that department.
Mark-B is offline
post #7 of 28 (permalink) Old 03-24-2015, 10:27 PM
Rebel Biker's Avatar
At 60 mph unless you're going DOWN hill...5th gear.
https://www.youtube.com/watch?v=KOZw...ature=youtu.be
2014 Victory Cross Country Tour - Two Tone Sonic Blue and Silver
PCV 6,500 rev limit, Lloydz VM1-DR Cams, Lloydz Hi Flow Filter, Atom Bomb exhaust, Lloydz ATS +4, Lloydz 1/4 Throttle. 111 HP / 116 TQ
2012 Victory Kingpin - Traded in on XCT
2007 Honda Shadow Aero 750 - Traded in on KP
Rebel Biker is offline
post #8 of 28 (permalink) Old 03-24-2015, 10:28 PM
Never run it under 2,000 RPM and do keep the revs up, especially in the twisties. I have her at 3,500 to 4,500 revs in the twisties and she loves it. Conversely, she hates it under 2K revs. 6th gear? Over 2,200+ Bacon.
post #9 of 28 (permalink) Old 03-25-2015, 04:44 AM
benm's Avatar
I usually run 6 at 100ks (60mph) but since fitting pipe and fuel control timing wheel I can go down to 80 k (50 mph) on the flat with no ill effects
2012 vegas 8ball, k&n filter,
rpw thor, wiseco fuel control.
Torque tube intake,
Wilbers shock, gold valve emulators ,
Batwing ,cruise control.
benm is offline
post #10 of 28 (permalink) Old 03-25-2015, 05:03 AM
dtmmil's Avatar
i run 6th as soon as i can, generally in 6th by around 55, if your doing hills and stuff then it might be different, but for me not a lot of hills
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
