Bigger front tire - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 04-26-2015, 05:15 PM Thread Starter
Default Bigger front tire
I have Monaco wheels and the 90/90-21 front tire. I went to go wider up front? Anyone done it? What did you use?
John R. is offline
post #2 of 11 (permalink) Old 04-26-2015, 05:31 PM
Default fatter tire
Go to the smaller front wheel. I know lots like the look of the 21", but you get more rubber on the ground with the smaller front wheel, there is also more choices of tires. If you can not find a fatter 21" front tire maybe somebody on this site might trade staight across. Good luck.
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
post #3 of 11 (permalink) Old 04-26-2015, 05:39 PM
Motorbikerx's Avatar
lu
Couple of questions JR, what bike you got and whats a Monaco wheel just out of interest have you got a pic?
My Vegas has a 90 90 21 front tyre on a Stingray wheel.
Ive purchased an XC. Front wheel, same as. Hammer to I think, measured everything and trial fitted when I serviced my forks last time....it fits....fender dont clear tyre it needs to be raised half inch or more to clear but looks a bit silly.
Thinx I need a Highball fender or similar to match both wheel and forks but they run a 16" so maybe itd need raising.
Bits n pieces aren't plentiful in OZ so experimentation is difficult. Ive got a biggish outback trip on the horizon and would like to mount it for that as cornering clearance aint an issue once on gunbarrel straight roads, just hanging on is
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 11 (permalink) Old 04-26-2015, 06:29 PM
Avon AV71 Cobra 120/70-21 Front Tire
http://www.jpcycles.com/motorcycle-tires/21-inch/front
post #5 of 11 (permalink) Old 04-26-2015, 06:49 PM
Default Nice
Nice looking tyre. I run the Avons on my XRs been very happy with them. That is a good looking tyre/tire and out to put mo rubber on the ground for you. You might have to move the fender up possibly so check it real good for clearance before you ride it after mounting it if you go that that larger Avon 21" tyre.
post #6 of 11 (permalink) Old 04-26-2015, 08:21 PM
Not too hard finding tires but is your wheel wide enough?
2011 vegas 8ball PCV, swept pipes rpw modified baffles, llyodz vm1-dr cam, ats +4, 1/4 throttle, ud pulley and ness intake.
KMC tuned 114hp/125ft/lbs
shanko is offline
post #7 of 11 (permalink) Old 04-26-2015, 08:59 PM
Travis P's Avatar
After 3000km or so I am very happy with my Avon Cobra 120/70r21.
Travis P is offline
post #8 of 11 (permalink) Old 04-27-2015, 06:59 AM Thread Starter
Not the look I'm looking for. Works on the Hammer but not on the JP.
Originally Posted by Motorbikerx View Post
lu
The bike is a JP and the Monaco wheel was an option back in '06. Nothing special.
That's what I'm looking for. A wider wheel and tire in the 21" that will fit the JP. If a mod needs doing, such as the fender, that's fine. I'd even go to a spoked wheel.
John R. is offline
post #9 of 11 (permalink) Old 04-27-2015, 12:26 PM
is this what your looking for
File Type: jpg 1507048_10153233560506995_5277497819718316269_n.jpg (33.7 KB, 29 views)
post #10 of 11 (permalink) Old 04-28-2015, 05:07 AM Thread Starter
I dig the look the Harley Breakout has. They placed a 130/60B21 63H on it. With the large rear tire, it makes the bike look great.
John R. is offline
