How to - install the MBW Turn signal load equalizer - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 12-22-2012, 06:37 PM Thread Starter
Default How to - install the MBW Turn signal load equalizer
Here is short install I did today on my 2011 Jackpot. I am putting LEDs on the front and rear, so I needed this LR-10 load equalizer from MBW. I installed the unit as MBW suggested, at the flasher unit. Remove the seat and it is located on the right side frame - inside. It is held on with a plastic push in fastener to the frame. I did NOT use the MBW wire taps, I soldered mine in place and used some black loom to dress up the wires. I checked continuity on the three wires needed, the Black, blue/red and Blue to make sure I had it right. I secured it to the frame rail as suggested and wire loomed the loose wires. Looks -
Pictures says it all......
Later
Tachdriver is offline
post #2 of 5 (permalink) Old 12-22-2012, 06:40 PM Thread Starter
Here is the finished product
post #3 of 5 (permalink) Old 12-23-2012, 12:14 PM
Not picking on you.
I always try to cut wires at staggered lengths so if there is a bear spot there will be nothing to short out.
I use shrink tubing that you can get in different sizes to cover soldered wires. In some cases I will put some dielectric grease on the solder area before shrinking the shrink tubing that will prevent corrosion.
You did explain what you did very nice and great photos
post #4 of 5 (permalink) Old 12-23-2012, 12:39 PM Thread Starter
I can assure you that all those wires are well taped and insulated. Better than stock.
Later
post #5 of 5 (permalink) Old 12-23-2012, 01:45 PM Thread Starter
Just got done putting the LEDs on front and rear - work GREAT and
look GREAT
later
