Need A Replacement Amber Turn Signal Lens - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 05-26-2016, 01:05 PM Thread Starter
Default Need A Replacement Amber Turn Signal Lens
Hello and thanks for any help in advance. I have a 2006 Cory Ness Victory Vegas Jackpot. There are amber turn signals on the front. I am in search of replacement amber lenses. I have not found a source to just buy the lenses, I have been told I need to purchase the entire turn signal assembly. If anyone has any extra amber lenses around they do not need anymore, I would appreciate the chance to purchase them. Once again, thanks in advance! Best regards, Marty
BlueyedCaptain is offline
post #2 of 8 (permalink) Old 05-26-2016, 01:28 PM
LILMAGS500's Avatar
I think I have 2 .......
LILMAGS500 is offline
post #3 of 8 (permalink) Old 05-27-2016, 08:30 AM
Crackpot Jackpot's Avatar
I have a set of front and rear factory turn signals just like yours w/ wire leads that have been converted to LED modules. Was going to put them on eBay but will refrain for now should you or others here be interested. PM me if interested. They are in excellent condition.
2009 Vegas Jackpot
280mm Metzler rear 21" Metzler front
Lloydz VFC & high-flo air filter
Numerous Arlen Ness custom add-ons
chrome swing arms & other chromed add-ons
Crackpot Jackpot is offline
post #4 of 8 (permalink) Old 05-27-2016, 10:35 AM Thread Starter
Thanks for your response, you can email me at [email protected]. Much apprcieated, Marty
post #5 of 8 (permalink) Old 05-31-2016, 11:07 AM
They are exactly like the ones you have pictured. Front signals have chromed plastic back housing & amber lens w/ fork clamps and the rear signals are black plastic housings & amber lens. I bought small bullet type, chromed metal signals since they are lower profile over the stocks ones, but they came with LED modules in them despite the seller stating they were incandescent lamps. Of course in testing them out they flash at a faster rate without the resistor installed. So I swapped the incandescent bulb sockets into the bullet ones and installed the LED modules into the stock Victory signal assemblies. They look pretty good.... you just need to wire in the resistor(s) to normalize the flash rate. I will try to PM you pics of them w/ one of them lit up.
2009 Vegas Jackpot
post #6 of 8 (permalink) Old 05-31-2016, 05:01 PM
BlueVegas's Avatar
I have a set you can have, you just pay the freight.
BlueVegas is offline
post #7 of 8 (permalink) Old 06-01-2016, 02:57 PM
Well there ya go - u can't beat that deal.
2009 Vegas Jackpot
post #8 of 8 (permalink) Old 06-01-2016, 04:08 PM
vindex1963's Avatar
There's a lot of good people here jumping at the chance to help I like that.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
