Throttle body adjustments by digital wrench - Victory Forums - Victory Motorcycle Forum
post #1 of 16 (permalink) Old 08-11-2016, 08:42 AM Thread Starter
slave600's Avatar
Default Throttle body adjustments by digital wrench
Soooo, my other thread was an attempt at finding what I might have done to cause my issues.... now I'm really confused!
the shop just explained to me that I may need a new throttle body because an adjustment they needed to make was out of spec...
this adjustment has fixed the erratic idle they claim but it has a value (-35) that means something is out of spec?????
what pray tell is he trying to tell me??
07 Vic. V. Jackpot
-RPW big slash
-K/N filter w/ vented airbox
04 Vic. Vegas
-twin turn downs
-vented airbox
slave600 is offline
post #2 of 16 (permalink) Old 08-11-2016, 08:57 AM
I didn't think throttle body's wore out but I guess the bushings in the flapper could wear out.
I've been cleaning my TB's with standard carb cleaner until a friend and mechanic recommended I use actual TB cleaning fluid. I didn't even know there was such a thing.
Amazingly it made a huge difference in how my 04 KP idles. In the past the I would have to use the idle increase lever on the left grip even when the bike sat for just 5 minutes. Now, after using the TB cleaner, I no longer need to increase the idle rpm speed. I can even let it sit for an hour or more in outside heat without needing to use the idle advance lever.
You may want to pick some up and clean your TB's with it to see if it makes as much difference for you. Apparently it dissolves junk/gunk/deposits in the TB the regular carb cleaner doesn't. There are different brands; here's just one.
http://www.autozone.com/fuel-and-eng...?checkfit=true
post #3 of 16 (permalink) Old 08-11-2016, 11:46 AM
I know this is easy for me to say. Why not get the bike put it in a truck and drive down to Kevinx. Or get the throttle body from dealer and overnight it to Kevinx and ask him to go thru it.
Your dealer sounds lazy and want the easy fix after they throw a bunch of parts at the bike.
post #4 of 16 (permalink) Old 08-11-2016, 11:52 AM
half_crazy's Avatar
Here's the problem...
If the Throttle Position Sensor (TPS) is bad, Victory won't sell you one, so you have to buy the whole throttle body.
If I'm not mistaken, the part is the same as most other bikes and you can likely buy one at NAPA for $35 or something stupid like that. It's just an ordinary TPS.
Another option would be an e-bay throttle body.
Victory throttle body in eBay Motors | eBay
2006 Victory Kingpin
half_crazy is offline
post #5 of 16 (permalink) Old 08-11-2016, 05:04 PM
Motorbikerx's Avatar
Typical Victory parts, gotta buy a complete unit cos they don't supply small parts.
Thanks for the info HC.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #6 of 16 (permalink) Old 08-11-2016, 06:06 PM
Maybe TPS help
https://thebikersgarage.wordpress.co...-a-motorcycle/
post #7 of 16 (permalink) Old 08-11-2016, 10:15 PM
Great article John. I'm going to bookmark that one.
I did look online for a 2014 tps just to see if I could actually find one. As far as I can tell the source in the article (walker) is presently only selling O2 sensors.
Maybe someone else will have better luck. It would great to have a source for that part down the road.
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #8 of 16 (permalink) Old 08-12-2016, 04:27 AM
half_crazy's Avatar
12 Victory Cross Country Throttle Body Sensor 1204321 | eBay
post #9 of 16 (permalink) Old 08-12-2016, 08:33 AM
NOEMTZ's Avatar
Did you notice the "Editors Note"?
We carry the TPS for the 106CI in stock.
www.noemtz.com
NOEMTZ is offline
post #10 of 16 (permalink) Old 08-12-2016, 09:14 AM
half_crazy's Avatar
There's good news!
http://www.noemtz.com/apps/webstore/...s/show/6915039
Fifty bucks.
