fuel controller options for lean conditions after cal. card - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 12 (permalink) Old 08-17-2016, 03:30 PM Thread Starter
slave600's Avatar
Default fuel controller options for lean conditions after cal. card
So I now have it from the tech that my bike is still lean even after the calibration card was installed.
I would prefer to use a simple plug and play style that I can download a map and use the bike without getting a dyno tune or spending the value of the bike in adding the new system...
current setup
-rpw big slash pipes
-k/n air filter
-hammer drag map calibration card
any suggestions for a model I can install myself? or a unit that has a solid level of communication with the technicians for installation?
I can be handy with the tools, but I don't wanna risk another trip to the dealer to install something I can do myself
07 Vic. V. Jackpot
-RPW big slash
-K/N filter w/ vented airbox
04 Vic. Vegas
-twin turn downs
-vented airbox
slave600 is offline
post #2 of 12 (permalink) Old 08-17-2016, 05:50 PM
what bike are you talking about. I see you have 2 listed
what makes you think its lean. Has the dealer hooked it up to their digital wrench.
What are you getting for gas mileage are you getting.
Popping or backfire does not mean its lean. Nor does heat coming off motor
post #3 of 12 (permalink) Old 08-17-2016, 08:01 PM
half_crazy's Avatar
Every time I read one of these threads... I want to stab myself in the throat.
Come on, man, there is probably a week's worth of reading on that subject on this forum.
Victory Forums - Victory Motorcycle Forum - Search Results
2006 Victory Kingpin
half_crazy is offline
post #4 of 12 (permalink) Old 08-17-2016, 09:34 PM
vindex1963's Avatar
Your links go nowhere.
To answer the question the vfc 3 is about as easy plug-and-play as you can get.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #5 of 12 (permalink) Old 08-17-2016, 09:49 PM
Luciferiad's Avatar
I think the reason these threads appear so frequently--at least now--is because there is truly an intimidating number of threads on the topic. Many of which wander a ways off course (we do tend to do that around here) and provide no definitive answer.
I myself have been wondering what makes a VFCIII different from the other Dobeck-style tuners like Wiseco and EJK, as they're a bit less expensive.
I'm getting into the market for some performance mods myself, and I've searched till my eyeballs hurt, but sometimes it's hard to find the answer you're looking for with so much material on the subject.
Mine:
2011 Cross Roads, crimson red
Hers
2015 Vegas 8-Ball
Luciferiad is offline
post #6 of 12 (permalink) Old 08-17-2016, 09:55 PM
vindex1963's Avatar
Decide what's important. I like a loooong stretch of highway or rural back roads so the basics air in air out simple tuner fit my needs. I ride the bike like an old man but have fun in the twisties but have never seen the point of flat out balls out beat the crap out of it, never been my style so I don't mod in that direction. Lots do and more power to them (or for them) I like the long haul not stop light to stop light so my bike reflects that.
slave600 likes this.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #7 of 12 (permalink) Old 08-18-2016, 09:54 AM Thread Starter
slave600's Avatar
I am looking to apply this to my 2007 jackpot.
I am well aware of the search function, but my riding style is geared more to cruising and I want smooth usable power for just riding it like a cruiser... not a sportbike or muscle bike.
-the Power commander series is expensive and has issues with erratic idle (according to the searches on the forum)
-the vfc seems a good option with a few issues with tuning (according to search)
-the Lloyd's controller is less expensive than the PC, but has some similar issues (search)
with so many options and almost no resources in my area I'm stuck with "dealing" with the sub-par service from the only dealership in the area with the digital wrench system (and the required cables) or doing it myself.
07 Vic. V. Jackpot
-RPW big slash
04 Vic. Vegas
-twin turn downs
-vented airbox
slave600 is offline
post #8 of 12 (permalink) Old 08-18-2016, 11:21 AM
slave600
you still didn't say why you think your bike is running lean.
post #9 of 12 (permalink) Old 08-18-2016, 11:36 AM
Travis P's Avatar
Your bike requires a PCIII or VFCII correct? Anything older than 2008... Both are good units and inexpensive.
Travis P is offline
post #10 of 12 (permalink) Old 08-18-2016, 01:09 PM
half_crazy's Avatar
Either bike would use a PC-III
The VFC-III (Victory fuel controller, generation 3):
This is a simple add-fuel-only controller. Push-button tuning.
PC-III: (Power Commander, 3rd generation)
This will add fuel or remove fuel at 9 throttle positions and every 250 rpm at each of those throttle positons, and it will tune each cylinder individually. Dyno tune is pretty much a must.
If you are not planning to make additional performance modifications, and if you don't care about perfect tuning, get the VFC.
