Rear LED Turn Signal Bar Upgrade - Victory Forums - Victory Motorcycle Forum
post #1 of 19 (permalink) Old 02-28-2013, 06:45 PM Thread Starter
Kenrock1000's Avatar
Default Rear LED Turn Signal Bar Upgrade
From eBay but looks killer!
vvv Video! vvv
Kenrock1000 is offline
post #2 of 19 (permalink) Old 02-28-2013, 10:50 PM
Looks good. Where in CA are you at? I'd like to see this. I was thinking about getting one, also what are you planning on doing with your plate?
2013 8-Ball
Victory Saddlebags
HID's
2" forward extensions
Cplkillian is offline
post #3 of 19 (permalink) Old 03-01-2013, 01:27 AM Thread Starter
Im in the Bay Area, Hayward. I have my plate bracket coming that mounts on the axle. Hoping it comes tomorrow.
post #4 of 19 (permalink) Old 03-02-2013, 10:00 AM
Hey man noticed your ape bars on the Vegas what size do you have and did you have to change the cables after installation? I am looking at the brcustoms 1 1/4" NEW WAVE 2 BARS what do you think of these. I'll attach the link of a youtube video where the owner talks about the bars.
new-vic-owner is offline
post #5 of 19 (permalink) Old 03-02-2013, 10:29 AM Thread Starter
Trying to find the height on them but they are either 9" or 12" tall. These are the stock Highball bars from Victory. Arlen Ness actually swapped them out for me after I bought the Vegas. They did swap out all the cables and related equipment.
http://www.purepolaris.com/en-us/Vic...-Ball%C2%AE%22
post #6 of 19 (permalink) Old 03-27-2013, 09:40 AM
I have the same rear kit coming for my highball, how did the install go any tips would be appreciated on the process
2012 Highball
jbyrd2006 is offline
post #7 of 19 (permalink) Old 03-27-2013, 11:19 PM Thread Starter
Not too hard at all. Pretty smooth install. Just take your time tucking/cable tying the wiring up.
2013 Victory Vegas 8 Ball
post #8 of 19 (permalink) Old 03-28-2013, 08:21 AM
have you done anything with your front turn signals, I am changing mine and have heard that Victory reversed the wiring on one of the signals for some reason
2012 Highball
post #9 of 19 (permalink) Old 03-28-2013, 09:14 AM
whatcaneyedo's Avatar
Here is my alternative to side mounting your plate if anyone else has saddle bags or laws to contend with. Cut the existing plate mount down, bend and drill some aluminum rail, then slap it all together.
If you switch your front signals to LED you'll probably need a load equalizer or resistor to keep the stock flash rate. To check for reversed polarity on the fronts one of those simple inexpensive circuit testers that lights up works just fine. I'm sure they have a proper name but I don't have time to look it up right now.
These are the MBW signals on my bike.
whatcaneyedo is offline
post #10 of 19 (permalink) Old 04-07-2013, 07:14 PM
Kenrock this looks great! Do you have a link to the kit you purchased on ebay, or at least a name for it? Also, where did you get your plate bracket from that mounts to the axle? I'd like to do this mod as well.
Passt is offline
