Advice on 07 Vegas 8 Ball - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 07-29-2013, 02:27 PM Thread Starter
Default Advice on 07 Vegas 8 Ball
Hi Guys
I've just bought an 8 Ball and love it. I wondered if anyone has any tips or advice on the first things I should do just to make sure I'm all sweet. It came with the stage 1 already but are there any areas that, based on your experience I need to be aware of. Cheers
D
Dangsta is offline
post #2 of 3 (permalink) Old 07-29-2013, 03:13 PM
clean the throttle bodys. Get some carb clean and do this maybe twice a year. Be really carfull pull gas tand and putting it back on.
http://buywitchdoctors.com/articles/...ictory-sc-598/
post #3 of 3 (permalink) Old 07-29-2013, 05:01 PM
Tims_04V92TC's Avatar
Read up on clutch cable lube or broken clutch cable. Plent of preventative tips there. You mentioned Stage 1 flash, what exhaust and intake you got? Huge improvements out there on that end. Tire air pressure, the bikes suspension will really do its job if you put that as part of your weekly checks. Be faithful on your oil change intervals, improved shifting with it. DONT over torque the plug and always replace the crush gasket each service. Go to Lloyds Tech tips on his web site and read up on his thoughts concerncing starts, cold starts and exhausts. Good stuff. My 2 cents on plugs is if your going to inspect them, replace them. VJ might disagree. heehe If it's an 07, new wires sooner than later might be a thought but you didnt mention milage.
Congrats on the new ride and welcome to the forums! Safe ridin!!!!
Tim
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
