check engine light at idle - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 05-25-2014, 12:38 AM Thread Starter
Default check engine light at idle
2013 8-ball under 6,000 miles. Check engine light comes on while in N or 1st while at idle at a stoplight. As soon as throttle is applied it goes away. Called the fealership, they said bring it in but I won't be able to for about 2 weeks, other than that they were useless. Attached is a pic of the code.
agmfi is offline
post #2 of 3 (permalink) Old 05-25-2014, 12:42 AM Thread Starter
Forgot to mention, no mods at all. Bike is completely stock still.
agmfi is offline
post #3 of 3 (permalink) Old 05-25-2014, 03:27 AM
Motorbikerx's Avatar
first thing to check on a vic is yr battery connections cos theres no lockwashers they can get a bit loose, clean, tighten and smear di-electric grease on em.
My Vegas throws red check engines sometimes and idles like shit, its the temp sensor on the front cylinder a white clip, try taking it off cleaning the contacts smearing with di-electric grease, may not fix it but certainly wont hurt.
someone here may no the error code I dont, my bike dont throw em up on the speedo, its gotta be plugged in .
The dealers and mechanics in Brisbane are great , no good to you though.
Good Luck
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
