Tank Badge removal help? - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 12-08-2011, 06:02 AM Thread Starter
Default Tank Badge removal help?
Has anyone been able to easily remove your tank badges? If so I am curious what method you used. I assume that they are attached VIA some sticky double sided tape but not 100% sure. I am looking to be enlightened.
In the past on other bikes I would soak the adhesive with some WD40 then remove. I assume some ginger work with a hair dryer may be in order to remove all of the adhesive, please advise.
05 Vegas 8 Ball
Southern, NJ
hyper15125 is offline
post #2 of 14 (permalink) Old 12-08-2011, 06:06 AM
Default hairdryer
all i used was a hairdyer worked great
george is offline
post #3 of 14 (permalink) Old 12-08-2011, 06:20 AM
BeoBob's Avatar
Why would you want to remove the tank badge... your'e just asking for more "Nice Harley" comments.
2013 Cross Country Tour: Custom paint, stage 1 exhaust, Lloydz Hi-Flow air filter, cams (HOH-VM1-DR), timing gear (HOH-PTS), Power Commander V, Auto Tune module, Gustafson flip shield, OEM passenger backrest with Cycle Ops luggage rack, Vic HID, heel shifter, Rockford amp, Infinity speakers all around.
2011 Cross Country: Burnt and Traded
BeoBob is offline
post #4 of 14 (permalink) Old 12-08-2011, 08:07 AM Thread Starter
You know, you bring up a good point!
05 Vegas 8 Ball
Southern, NJ
post #5 of 14 (permalink) Old 12-08-2011, 09:33 AM
Donzo's Avatar
I am considering taking off the badges to put on the "vintage" looking badges.
2010 Crossroads
Midnight Cherry
No Rice
No Pork
Just Beef
Enjoy the miles....we only get so many!
Donzo is offline
post #6 of 14 (permalink) Old 12-08-2011, 09:42 AM
PrairieSon's Avatar
I removed mine simply for a cleaner look. I used a heat gun from a distance and just peeled them off slowly. Be sure not to scratch the tank paint with the edges of the badge. You gotta pull is straight off with two hands.
I then used some good bug and tar remover to get all the glue off. Looks slick. Good luck.
2011 XC Black
2010 JP Black
2008 Vegas 8ball
PrairieSon is offline
post #7 of 14 (permalink) Old 12-08-2011, 10:33 AM
gamewarden's Avatar
Will the above tecniques also work for the two black and orange warning labels. Bike sold in Canada so some of you may not have them stuck on your tanks above filler cap. I am a little nervous about removing them.
Thanks
2011 custom Tequila Gold with Candy Orange accents, hard lowers and trunk, Ipod in lowers, HID and saddle bag bars, stage 1, heel shifter, front and back chrome fender guards,Garmin GPS, fairing wind deflectors, heated Gerbing hook up, Dain skull brake pedal, rear brake master and reservoir cover, custom cheese wedge cover, clutch cover, Witchdoctor cam covers, Wolo Bad Boy horn, heated grips and seat, Gorilla alarm, Vision rear engine brackett covers, Kruzer Caddy, WD exhaust tips.
gamewarden is offline
post #8 of 14 (permalink) Old 12-08-2011, 12:48 PM Thread Starter
Thanks
I don't see why not. I would not get too close to the tank with the hair dryer or heat gun through. Just a sweeping motion back and forth from a distance to head up the adhesive. On painted surfaces I usually use and old cotton sock turned inside out with WD40 to remove the adhesive.
05 Vegas 8 Ball
Southern, NJ
post #9 of 14 (permalink) Old 12-08-2011, 09:58 PM
mattf's Avatar
i used some power pro fishin line and just slid it behind it. i got the color ones from barracuda customs. i like them alot better. the factory ones looked like they could just fall off and didnt seem to fit right.
mattf is offline
post #10 of 14 (permalink) Old 01-14-2012, 07:53 PM
theteese's Avatar
Fishing Line x 2 ( Piece of Cake ).
Wipe off excess tape with Goo Off.
No heat gun or anything else required.
Cheers
AL
theteese is offline
