Gear box slippage between 6th and 5th. - Page 2 - Victory Forums - Victory Motorcycle Forum
 12Likes
post #11 of 20 (permalink) Old 09-05-2018, 05:42 PM Thread Starter
Thanks for the replies everyone.
Regarding the speed at which I was going when this was happening, it was about 120kph. Divided highway speeds.
The clutch cable, too tight? That's odd. One would think it would become too loose as time went on. I'll check it out tho.
2015 Victory Highball
the.tru.albertan is offline
post #12 of 20 (permalink) Old 09-05-2018, 06:05 PM
post #13 of 20 (permalink) Old 09-07-2018, 07:12 AM
gamewarden's Avatar
I had the same problem once and found that the nylon nut holding the clutch lever in its housing had tightened itself up somehow. I loosened it off and all was good. Just something to check.
2011 custom Tequila Gold with Candy Orange accents, hard lowers and trunk, Ipod in lowers, HID and saddle bag bars, stage 1, heel shifter, front and back chrome fender guards,Garmin GPS, fairing wind deflectors, heated Gerbing hook up, Dain skull brake pedal, rear brake master and reservoir cover, custom cheese wedge cover, clutch cover, Witchdoctor cam covers, Wolo Bad Boy horn, heated grips and seat, Gorilla alarm, Vision rear engine brackett covers, Kruzer Caddy, WD exhaust tips.
gamewarden is offline
post #14 of 20 (permalink) Old 09-08-2018, 08:49 AM
To the OP... did you go to the last RevUp Rally at Revelstoke in July? I had planned to go with a few Red Deer buddies, but it was either that...or visit my parents who I hadn't seen for 4 years in Sask. Didn't have the time to do both.
2016 Victory Magnum
Lloydz air filter
Ragin Cajun slipons
PowerVision CX
Tenax is offline
post #15 of 20 (permalink) Old 09-10-2018, 10:21 AM
Judge Redd's Avatar
@half_crazy showed me that the adjustment specs in the book are NOT appropriate- at least- they are not appropriate if you have some go fast goodies installed.
I was having the same symptoms: A periodic slip in high gear. This on a relatively NEW clutch- i.e. installed 2017 riding season. Like RICZ said- your clutch is too tight.
Wise man Larry say: "Fuck that book. I can't read." Warm up first. When at speed- Pull in the clutch a little bit. If your clutch is disengaging with very little pull- it's too tight.
I popped my side cover off- and Larry pulled his glasses down a little bit and scared the adjustment turnbuckle a turn or so. Clutch pull strong now.
2014 Judge(Havasu Red) PC-V - ATS(+4) - RPW Boom Sticks - HOHVM1-DR cams - Torque Tubes (dyno sheet) 1/4 turn throttle - OPT7 LED headlight kit - OEM bags, backrest, and W/S
Judge Redd is offline
post #16 of 20 (permalink) Old 09-10-2018, 05:04 PM
half_crazy's Avatar
LOL... Actually, I used a Crescent Hammer and a 13mm wrench.
It's almost impossible to static adjust a Victory clutch and get it right.
Yeah, higher gear and some throttle... put a load on it... give the lever a slow tug. It needs to move a bit before the revs come up (disengaging). If as soon as you touch it the revs go up, "I found the problem!".
How ya doin'? Ready for the hurricane that's rollin' in?
2006 Victory Kingpin
half_crazy is offline
post #17 of 20 (permalink) Old 09-10-2018, 05:17 PM
half_crazy's Avatar
Originally Posted by RICZ View Post
Funny thing--if I'm traveling under 75 in 5th gear, she gets better fuel mileage. Prolly less strain on the engine, ya think?
Ya know, everyone is in a big hurry to get into the highest gear possible as soon as possible... If I'm rolling at 60-65 in 5th it will get way better fuel mileage than it will if I shift 6th. Moral of the story? When you think you need to shift up, don't, leave the shifter alone. There's no law that says you must be in the highest gear possible. Let it spin some, it won't hurt it.
post #18 of 20 (permalink) Old 09-11-2018, 09:09 AM
Judge Redd's Avatar
I've decided to forgo grab-assin' with Florence & fly to the Texas hill country for the remainder of the week so I can flirt with the 3 Twisted Sisters instead.
(actually set this up weeks ago)
half_crazy likes this.
post #19 of 20 (permalink) Old 09-11-2018, 12:40 PM
half_crazy's Avatar
I've decided to forgo grab-assin' with Florence & fly to the Texas hill country for the remainder of the week so I can flirt with the 3 Twisted Sisters instead. (actually set this up weeks ago)
I'll be dancing with Florence, I just hope she lets me lead....
post #20 of 20 (permalink) Old 09-14-2018, 03:49 PM
Honda East Toledo's Avatar
The quarter rule of thumb not apply on these bikes?
(419) 891-1230 ext 235
(877)-437-1631
http://www.hondaeasttoledo.com
http://www.hondaeastsuperstore.com
Like us on Facebook
Follow us on Twitter!
Honda East Toledo
Indian Of Toledo
1230 Conant St.
Maumee, Ohio 43537
Honda East Toledo is offline
