Gear box slippage between 6th and 5th. - Victory Forums - Victory Motorcycle Forum
 12Likes
post #1 of 20 (permalink) Old 09-03-2018, 03:26 PM Thread Starter
Default Gear box slippage between 6th and 5th.
Hello again all, been a while since I posted on this forum.
We did a trip from Alberta to BC back in July. I noticed on the way home from that trip that there was something happening to the power of my bike while on the highway going at speed. It would almost be like my rear wheel was spinning out when I gunned the throttle in 6th gear.
Forgot all about this until a couple days ago. I was back on the highway, in 6th gear and I gunned it, felt the same slippage again but I noticed that the gear indication on the tach was displaying 5th. When I stopped gunning it, the indication went back to 6th. Gunned it again, watched the display switch to 5th, released throttle, display read 6th again.
Did this a few times. Hit an off-ramp and downshifted. Tried the same throttle use as before but experienced no problems between 5th/4th and 4th/3rd. Only seems to be a problem while in 6th gear and heavy throttle.
Not a big deal, just wondering if anyone is having a similar experience.
2015 Victory Highball
the.tru.albertan is offline
post #2 of 20 (permalink) Old 09-03-2018, 03:46 PM
half_crazy's Avatar
Clutch is slipping.... revs go up, but bike is not accelerating...
yago20 likes this.
2006 Victory Kingpin
half_crazy is offline
post #3 of 20 (permalink) Old 09-03-2018, 04:17 PM
+Check your clutch cable adjustment. It might be too tight. There should be some slack to the cable and an easy way to determine that is wiggle the exposed cable down at pivot. This needs to be checked frequently.
+If you are member of the "I don't want to hurt my engine by going over 3,000 RPMs Club," that will overwork a clutch. You should not go into 6th gear until you are doing over 70 MPH, or 113 KPH. Endeavor to keep revs at or above 3,000 RPM.
+ Make certain that the oil you are using is rated JASO-MA or MA2. That means it's intended for wet clutch engines.
+ The reason your gear indicator went bonkers is that it gets its info from a bike speed sensor and an engine speed sensor. So when the clutch is slipping, it thinks you dropped down a gear. It's just doing the job it was designed to do.
I hope this helps.
RICZ is online now
post #4 of 20 (permalink) Old 09-03-2018, 09:35 PM
If you don't adjust it quickly you will be replacing it very soon. Almost momentarily.
RICZ, half_crazy and BP6666VR like this.
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #5 of 20 (permalink) Old 09-03-2018, 10:35 PM
BP6666VR's Avatar
Do you have a Eazy Clutch installed on your clutch arm OP ?
Like everyone mentioned check your freeplay ....
Andre using TaPaTaLk
yago20 likes this.
Cross Country Tour 2014 [B]
BP6666VR is offline
post #6 of 20 (permalink) Old 09-04-2018, 08:58 AM
DaveT's Avatar
clutch...Clutch...CLUTCH!
DaveT is offline
post #7 of 20 (permalink) Old 09-04-2018, 10:49 PM
cra-z1's Avatar
He never stated how fast he was going. I agree RICZ, he should not be in 6th unless he is at least 70 or above. I never get mine into 6th unless im doing 75-80. When I first got the bike I had the same experience with what I thought was a slipping clutch. It was in 6th doing 65 with a strong headwind. The bike likes to be in the higher revs.
Coeur d Alene Idaho, formally MPLS. 2009 KingPin, 2011 KingPin 8 Ball,
cra-z1 is offline
post #8 of 20 (permalink) Old 09-05-2018, 12:34 AM
Funny thing--if I'm traveling under 75 in 5th gear, she gets better fuel mileage. Prolly less strain on the engine, ya think?
RICZ is online now
post #9 of 20 (permalink) Old 09-05-2018, 12:47 PM
maybe this will help
post #10 of 20 (permalink) Old 09-05-2018, 12:49 PM
some more
