4 valve water cooled Indian - Victory Forums - Victory Motorcycle Forum
post #1 of 33 (permalink) Old 12-16-2013, 09:11 AM Thread Starter
Default 4 valve water cooled Indian
Was in the right place at the wrong time. Over heard someone talking about a 4 valve water cooled Indian engine yet to be release.
Let the screaming begin.
wkohn is offline
post #2 of 33 (permalink) Old 12-16-2013, 10:29 AM
half_crazy's Avatar
I heard 'someone' say the Indian engine was made in Japan and that Polaris was a Canadian company. Doesn't make it true.
2006 Victory Kingpin
half_crazy is online now
post #3 of 33 (permalink) Old 12-16-2013, 10:32 AM
vindex1963's Avatar
Now that Harley is going water cooled we need another rumor victim might as well Be Indian.
I have a friend in a service department in a dealership that hasn't been built yet that says Indian is going water cooled.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is online now
post #4 of 33 (permalink) Old 12-16-2013, 10:44 AM
dope_man_21's Avatar
I heard since Harley is going water cooled they are testing turbos on all of the 110 CI engines
$20,000 and 3000 miles DO NOT make you a biker
2013 Victory HighBall
Patriot Guard #156315
dope_man_21 is offline
post #5 of 33 (permalink) Old 12-16-2013, 11:40 AM
busajack's Avatar
I put this supercharger on a S&S 107 and gained 13 measly HP.
Blowing V twins is a black art and Hardly could never get it right.
I have to grow old but I don't have to grow UP.thumb up. 2010 Jackpot.
busajack is offline
post #6 of 33 (permalink) Old 12-16-2013, 12:52 PM
I wonder how much parasitic loss there was on that...
S&S Cams, Lloydz filter & ATS +5, PCV, UD pulley, Alto Red Eagle clutch pack
Madstad Windshield, 5000K HID, TriOvals, Memphis Shields wings
JVC KD-X33MBS, PBR300X4, Polk DB6502, DaytonAudio ND140-4 rear
HyperLites, LED driving lights, hydraulic clutch, Ultimate seat
post #7 of 33 (permalink) Old 12-16-2013, 01:26 PM
busajack's Avatar
Probably a bunch.
older Vtwins that shared the intake plenum don't have the volume to build enough boost in the plenum to feed both cyls.
Was a fun but expensive experiment.
busajack is offline
post #8 of 33 (permalink) Old 12-16-2013, 01:30 PM
CrossRoads's Avatar
I think through Victory and Indian, Polaris is holding an engineering lesson on how to build an air cooled motor without the shortcomings of HD. They have no reason to whimper and build a liquid cooled bike.
Whoever's starting these rumours must be dilusioning themselves in thinking Indian is following HD.
CrossRoads is offline
post #9 of 33 (permalink) Old 12-16-2013, 01:47 PM
saddlebag's Avatar
Following Harley? They are like the last people on earth to figure it out. BMW just did the same type of hot spot cooling that Harley did and they were able to pull like 20% more HP out of their boxer.
If you read the last comparison of the Harley vs Indian, the Harley actually made more top end power than the Indian and that was just the air-cooled 103. If Indian executed a well designed system that worked as well as Beemers, it would flat smoke the Harley. And that's BEFORE they put better flowing 4 valve heads on it.
The other benefit is heat reduction. If you've had a chance to ride an Indian, then you likely realize that that is an area that could stand to be addressed.
2011 Cross Roads
saddlebag is offline
post #10 of 33 (permalink) Old 12-16-2013, 01:49 PM
saddlebag's Avatar
I wonder if he had to add balast to the right side of the bike to keep it upright.
2011 Cross Roads
