21" front wheel - Victory Forums - Victory Motorcycle Forum
post #1 of 24 (permalink) Old 12-29-2014, 04:25 AM Thread Starter
Default 21" front wheel
I know I know, if I didn't like the wheel size, should a bought a jackpot But this is what I got.
Any ideas on why I can't buy a jackpot front wheel and put it on my hammer?
2010 Hammer 8-ball
From Harley to Victory -- very happy customer!
Seven71ne is offline
post #2 of 24 (permalink) Old 12-29-2014, 06:06 AM
Krisd's Avatar
Why would you just look at Jackpot 21" wheels when there are so many other 21" brands that fit? Are you trying to match it to your rear wheel?
2012 Hammer S
Freedom Performance pipes now wrapped, PCV, Loyds air filter, ATS, Loyds Cams and 1/4 Turn Throttle adj, Progressive rear shock
300mm rear and 23" front
Krisd is offline
post #3 of 24 (permalink) Old 12-29-2014, 08:21 AM Thread Starter
That would be the cheaper route, but either way, any 21" front wheel, would it even work? I know that the front fender wouldn't work..
2010 Hammer 8-ball
post #4 of 24 (permalink) Old 12-29-2014, 11:02 AM
I am in the same situation. Previously owned a Vegas but had to sell it few years ago. Got another opportunity this year buy a Victory and got a great deal on a hammer that I couldn't pass up. I didn't think I would miss the 21" but I actually do.
I get the whole "why not just get a Jackpot argument" and hindsight is 20/20. But instead of selling my hammer and getting a Jackpot, it seems like a lot less hassle to just swap out the front wheel, if thats all there is too it.
From searching the forum, it appears all that is needed are spacers to center the wheel and a new front fairing or modifying the stock fairing bracket. Can anyone confirm? Thanks!!
misterjj is offline
post #5 of 24 (permalink) Old 12-29-2014, 02:01 PM
leighhannah's Avatar
There are a few things that are different from the Hammer to Jackpot/Vegas wheels. The first being that the Hammer is typically a dual rotor setup while the Vegas/Jackpot is a single rotor. Vegas/Jackpot wheels are not made to accept a rotor on the right side of the wheel. The second, as you already mentioned is the fender size and mounting setup (easily overcome). Third, (someone please correct me if I'm wrong) the hubs are different. I believe that the width between the forks on the Vegas/Jackpot is different from the Hammer.
2008 Vision Street
Custom paint; tinted turn signals; Lloydz cams, timing gear, PCIII; Hot Vic 26" Windmill wheel, billet wedges, tips, pegs & covers; Focal IC-130 5.25" speakers, Arc Audio KS 125.2 BX2 AMP; Hot Tails custom seat...
2012 High Ball
Custom exhaust; high performance air filter; Hot Vic sissy bar, lowered 1.5" rear, .5" front; Witchdoctor 2" peg extensions & pegs, Hot Tails custom seat & passenger pad...
leighhannah is offline
post #6 of 24 (permalink) Old 12-29-2014, 02:12 PM
Originally Posted by misterjj View Post
...From searching the forum, it appears all that is needed are spacers to center the wheel and a new front fairing or modifying the stock fairing bracket. Can anyone confirm? Thanks!!
Yes you could cut new spacers to center the wheel, but don't forget the rotor. I believe you'll have to shim it as well.
2008 Vision Street
2012 High Ball
post #7 of 24 (permalink) Old 12-29-2014, 03:25 PM
Krisd's Avatar
Ah, OK.
Yes a 21" or 23" will bolt straight on- you do not need any mods for the rotors. In fact a 21" does not require any different parts to what you already have, and a 23" will only require a new fender (i.e. your current fender is OK for a 21"- you may need longer arms, from a Jackpot say, but the profile of the fender is OK).
You may still need to do some shimming as stated above however.
2012 Hammer S
Krisd is offline
post #8 of 24 (permalink) Old 12-29-2014, 10:05 PM
Motorbikerx's Avatar
I trial fitted an XC//Hammer front wheel (theyre the same wheel I think) 130/70/18
to my Vegas before I pulled the forks down the other night.
It fitted great, would give me more rubber on the road, my vegas disc rotor would bolt on, but it'd give me even less ground clearance.
Right hub width though using Vegas spacers...here it is!
Went back to my 21" but
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #9 of 24 (permalink) Old 12-29-2014, 10:50 PM Thread Starter
My hammer only has one rotor
2010 Hammer 8-ball
post #10 of 24 (permalink) Old 12-29-2014, 11:07 PM
Krisd's Avatar
8 Ball Hammers have one rotor, Hammer S has 2- so yours is the same as a Vegas or Jackpot.
2012 Hammer S
Krisd is offline
