2012 hammer tail laight LED ?? - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 04-12-2015, 02:39 PM Thread Starter
Default 2012 hammer tail laight LED ??
I want to install a better tail light- brighter one. It is LED. They say you have to have a converter to convert 3volts to 12volts for it. But if our 2012 tail light is already LED, do I need the converter ?
Is the 2012 stock LED from the factory ?
Later
Tachdriver is offline
post #2 of 5 (permalink) Old 04-19-2015, 08:24 PM
Mr_Buzzcut's Avatar
no you dont need it. The older Hammers had the 3 volt. yours is 12. I switched to the 15 led light and needed the converter.
2008 Hammer S
300mm Fat tire
USMC 87-92
Mr_Buzzcut is offline
post #3 of 5 (permalink) Old 04-19-2015, 11:00 PM
NOEMTZ's Avatar
Later
YES!
the 2012 is already the multi LED one being sold as an upgrade for older model single dual stage LED bulb version that was used up to 2007.
www.noemtz.com
NOEMTZ is offline
post #4 of 5 (permalink) Old 04-22-2015, 07:36 AM
Mr_Buzzcut's Avatar
The 3 volt single led was actually sold up to 2008. I converted mine to the 15 Led. also.
post #5 of 5 (permalink) Old 04-22-2015, 09:47 PM
Krisd's Avatar
Later
Tach- are you doing this before you sell? (or have I got that wrong???)
In any case, I have the LED strip that I bought in 2013- are the newer ones significantly brighter?
Thanks man
2012 Hammer S
Freedom Performance pipes now wrapped, PCV, Loyds air filter, ATS, Loyds Cams and 1/4 Turn Throttle adj, Progressive rear shock
300mm rear and 23" front
Krisd is offline
