Electrical problem 2007 Hammer - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 06-30-2015, 05:45 AM Thread Starter
Default Electrical problem 2007 Hammer
Hey guys. Previous owner lowered the bike and had 0 preload on the shock and never had a passenger on the bike. You can guess what happened. Had my girlfriend on the bike and the tire rubbed the wires. Blew the 15A fuse and i took the fender off and fixed it. This happened a second time after adding a bunch of preload. Only this time the left turn signals arent working at all. It flashes on the cluster and thats it. Even with the rear fender plug off the front left turn signal doesnt work. Everything else appears to be working fine. I did make the mistake of putting a 25A fuse in where it was a 15A because its all i had and i wanted to see if it was working the first time i fixed it, and i forgot about it. So far i've separated all the wires and wrapped them in electrical tape where they were bare. I'm thinking its a ground issue, even though according to the schematic the right turn signals share the same ground. Also, i've checked to make sure the bulbs weren't burnt out. Any help would be appreciated, thanks.
OhioPatriot308 is offline
post #2 of 6 (permalink) Old 06-30-2015, 05:54 AM
kevinx's Avatar
Fried auto cancel module
kevinx is offline
post #3 of 6 (permalink) Old 06-30-2015, 06:50 AM Thread Starter
Yea just discovered that after doing some searching Its always something. Live and learn. Have you ever heard of someone repairing one? Especially if everything else works. Its just really painful to fork out $250 for something that doesnt add horsepower
post #4 of 6 (permalink) Old 06-30-2015, 11:47 AM
maybe this
http://www.jpcycles.com/product/381-...+NON-BRAND+PLA
post #5 of 6 (permalink) Old 06-30-2015, 02:06 PM
zxmikez's Avatar
Default Aftermarket tail/signal light
Since you are doing surgery, you might want to add this thing:
http://www.mbwmotorcycle.com/products/hammer.html
Definitely cleans up the look of the tail, and eliminates the outboard signals
2007 Hammer Premium
zxmikez is offline
post #6 of 6 (permalink) Old 07-01-2015, 06:30 AM Thread Starter
Since the ACM is potted i'm going the alternative and hopefully free route and unpot it and find where its fried. You can use a heat gun and an exacto knife to remove the epoxy and eventually get to module. I will take pictures along the way and post results. This could eventually help alot of people
