19" front wheel? - Victory Forums - Victory Motorcycle Forum
post #1 of 2 (permalink) Old 10-21-2015, 05:46 AM Thread Starter
CraaagV's Avatar
Default 19" front wheel?
I think this would be a much easier swap out than a 21" and still give a little more presence to the front wheel. To me the 18" looks a little undersized.
The rake would likely be ok as the change isn't much? What about the fender height? Is there some sort of brackets to change their position or will I still need something custom?
Wheel size is 3.5" on the current front width and does 3" work? Most 19" I've seen list width as 3".
Thanks!
CraaagV is offline
post #2 of 2 (permalink) Old 01-31-2016, 11:15 AM
Default costly
a small difference for big $$$$! unless changing the set or going to lighter wheels the minimal difference will be money poorly spent IMO, but its your $$$$$. i would prefer downsizing the overly big + heavy rear setup. a 17" wheel with a 200-55-17 is about the same diameter but surely lighter with a 6 or 6.5 inch rim
rodhotter is offline
