Power Commander 3 for Hammer - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 12-28-2015, 12:45 PM Thread Starter
Default Power Commander 3 for Hammer
I'm looking for some advice on which map I should use on a Power Commander 3 for my 2006 Hammer. I installed the Stage 1 Drag kit with the K&N filter and box cover (Part number 2875670).
There are two maps that look almost right:
921-001 2005 Victory Hammer Victory Stage 1 Kit
921-006 Victory Stage 1 drag pipes, S&S air box
or is there another map you know of that might work better?
Model with list of maps
http://www.powercommander.com/powerc...dl=360&yr=1256
2006 Hammer
Graptor is offline
post #2 of 11 (permalink) Old 12-28-2015, 03:13 PM
write Rylan at the vic shop and get a great map from him. tell him every detail to get the most. Get a Lloydz timing wheel for real power
[email protected]
post #3 of 11 (permalink) Old 12-29-2015, 06:19 AM
kevinx's Avatar
Canned maps do not work well at all for 02-07 Vic's with PC3. Timing wheel is not very signifigant in pre 08 bikes
kevinx is offline
post #4 of 11 (permalink) Old 12-29-2015, 09:18 AM Thread Starter
When you say they don't work well, what do you mean? Will they stop the popping but, not give added performance?
2006 Hammer
Graptor is offline
post #5 of 11 (permalink) Old 12-29-2015, 09:45 AM
half_crazy's Avatar
He means you need to get the bike on a dyno and have it tuned. The combination of parts you have chosen are not going to give you much in the way of power, and the Power Commander doesn't 'make power' at all... the Power Commander is simply a means to tune the engine to whatever your combination of parts may be.
2006 Victory Kingpin
half_crazy is offline
post #6 of 11 (permalink) Old 12-29-2015, 12:29 PM Thread Starter
Yes, exactly all I'm looking to do is tune the engine to the parts I now have installed. I'm not looking to tune the engine for optimum performance. Like my original question states, I'm just looking to run the best of the two programs to stop the popping that I'm having since installing the pipes. The stock hammer has all the power I need.
2006 Hammer
Graptor is offline
post #7 of 11 (permalink) Old 12-30-2015, 09:10 AM
Cali Phil's Avatar
Though I know nothing I think what you are missing is no 2 bikes are the same. What is good for one may be ok for another but could also cause a different problem. The best way to get what you want is to get it dyno tuned. IMO if you are getting a power commander of any kind it should be with the intention of getting it dyno'd as that is it's real purpose. Get the optimum fuel mileage with the benefit of a machine that runs the way it should. This is why I haven't gone this route yet.
2006 Victory Vegas 8ball Santa Rosa Ripper exhaust, Thirdgear intake, Power Commander 3
I live in beautiful Mount Shasta Calif. Where heaven and Earth meet.
Cali Phil is offline
post #8 of 11 (permalink) Old 12-30-2015, 10:18 AM
half_crazy's Avatar
Everyone says that... at first...
post #9 of 11 (permalink) Old 12-30-2015, 11:44 AM
not sure how far you are from Pine Bush Ny. Go see Lloydz he's the guru for Vic's
post #10 of 11 (permalink) Old 12-31-2015, 07:26 AM Thread Starter
Thanks for all the feedback guys, I'll have to think about going through the expense of getting it on a Dyno and trying to find someone in the Rochester area, that can do that type of work.
I've installed the PC and it seems to be idling smooth with the "921-006 Victory Stage 1 drag pipes, S&S air box" map. While rolling the throttle the pops are gone as well. I won't be able to really tell if its running as good as I need until the spring. Salted ice covered roads are not my thing.
The bike couldn't even run with the first stock map I tried, "921-001 2005 Victory Hammer Victory Stage 1 Kit". it would die very quickly.
2006 Hammer
Graptor is offline
