Idle speed high - Victory Forums - Victory Motorcycle Forum
 9Likes
post #1 of 14 (permalink) Old 06-13-2016, 05:00 PM Thread Starter
Default Idle speed high
I have a 2006 Hammer. My resting idle speed has been right around 1,000. I cleaned out the throttle body's and now it's running around 1,500 at a stop. Is there a throttle adjustment screw on the 2006? Or could there be some other problem?
2006 Hammer
Graptor is offline
post #2 of 14 (permalink) Old 06-13-2016, 05:17 PM
don't be leave you can adjust idle. Dealer can reset your TPS and that should lower your idle
Graptor likes this.
post #3 of 14 (permalink) Old 06-13-2016, 05:48 PM
BlueVegas's Avatar
Did you check your idle advance?
Graptor likes this.
BlueVegas is offline
post #4 of 14 (permalink) Old 06-13-2016, 05:56 PM
NOEMTZ's Avatar
Check for vacuum leaks on tb boot and ports for California emissions. If all ok. 06 has idle adjustment screw on left side of tb. Back it down a bit if you still have a small amount of free play on your fast idle. That will keep you going until a factory TPS reset can be done.
Graptor likes this.
www.noemtz.com
NOEMTZ is offline
post #5 of 14 (permalink) Old 06-13-2016, 06:01 PM Thread Starter
This has me thinking that I should check my fuel controller. I wonder if disconnecting the battery reset it
2006 Hammer
Graptor is offline
post #6 of 14 (permalink) Old 06-13-2016, 09:41 PM
NOEMTZ's Avatar
Should not reset with power interruption as it should shut off every time bike turns off. Now if it does not have a good enough ground or power source while running, that could cause idle issues.
Graptor likes this.
www.noemtz.com
NOEMTZ is offline
post #7 of 14 (permalink) Old 06-15-2016, 03:21 AM
benm's Avatar
you could try this
https://www.victoryforums.com/36-vict...t-why-how.html
or I think Lloyd has a procedure on his site
Graptor likes this.
2012 vegas 8ball, k&n filter,
rpw thor, wiseco fuel control.
Torque tube intake,
Wilbers shock, gold valve emulators ,
Batwing ,cruise control.
benm is offline
post #8 of 14 (permalink) Old 06-15-2016, 06:33 AM
Motorbikerx's Avatar
it happened right after you cleaned your throttle bodies...
Id be looking for a vacuum leak first up
Graptor likes this.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #9 of 14 (permalink) Old 06-15-2016, 09:32 AM
Jamming's Avatar
I'd take this advice....use a little spritz of WD40, the idle will change when you find the leak.
Graptor likes this.
I eat, breathe, live, love and ride motorcycles.
4 wheels move the body, 2 wheels move the soul.
Wiseco fueler, Lloyds timing gear +4, Thrush modded mufflers and LLoyds air filter.
Jamming is offline
post #10 of 14 (permalink) Old 06-15-2016, 02:55 PM
Marius's Avatar
This being a 2006 bike, I bet that rubber throttle body adapter is rotten and cracked. Pull the cheese wedge off on the right side of the bike, visually locate the rubber throttle body adapter. With the bike cold, start the bike and spray carb cleaner around the throttle body adapter and see if the idle rpm changes or if the bike kills. I like to do this with the straw attached to the carb can so that you have a better idea of where the leak is, if there is one. If spraying carb cleaner on the adapter changes the idle, that adapter is cracked and needs to be replaced.
BTW: I wouldn't do this on a HOT bike because carb cleaner is highly flammable.
Otherwise, you probably just need to adjust the throttle idle lever or the throttle cable. Both are adjustable on these bikes.
If it turns out to be a cracked throttle body adapter, this thread may help:
https://www.victoryforums.com/36-vict...1500-rpms.html
Graptor likes this.
2007 Victory Hammer (Nuclear Sunset)
2012 Vstrom Adventure 650
2006 Suzuki M50 (Black) - Traded
1995 Mustang GT... Work in Progress...
Marius is offline
