4 inch forward controls questions - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 03-03-2014, 06:59 PM Thread Starter
Default 4 inch forward controls questions
Okay, I have the 4 inch controls installed, having an issue with the brake lines. The stock banjo fitting into the t block is awkward and the new line is rather long. Could someone post a picture of how they installed theirs? Thanks
2013 Hammer "MJLNIR" Kennewick WA
Lloydz TT intake
Lloydz ATS wheel
RPW Big Slash
Lloydz IAV
Ness Fly Bars
ISO grips
Victory HID
chaz7887 is offline
post #2 of 11 (permalink) Old 03-03-2014, 07:28 PM
lunaticrider's Avatar
I loosened the banjo bolt when I installed my forward control brackets, it allowed me to adjust the brake line to the angle I thought was best. Just remembered you have to bleed the rear brake if you crack the banjo bolt loose....
2012 Hammer 8 Ball - All upgrades are listed in my Garage
If racing was outlawed ... Then only outlaws would race ...
lunaticrider is offline
post #3 of 11 (permalink) Old 03-03-2014, 07:32 PM Thread Starter
But with the 4 inch, it comes with the t block and a new hose. I just want an idea what it looks like with this kit. It just seems there is a lot of slack with the new hose. I want it to look clean and with this setup, just not seeing how it will.
Lloydz TT intake
Lloydz ATS wheel
RPW Big Slash
Lloydz IAV
Ness Fly Bars
ISO grips
Victory HID
chaz7887 is offline
post #4 of 11 (permalink) Old 03-03-2014, 08:31 PM
I installed a 2 inch homeade kit, so I was able to keep all stock parts. Do you have a pic of how much brake line you need hide?
post #5 of 11 (permalink) Old 03-03-2014, 08:34 PM
Depending on how much longer the new brake line is you should be able to get rid of some by pulling rearward on the brake line along the lower frame...
post #6 of 11 (permalink) Old 03-03-2014, 08:47 PM Thread Starter
I can't do that. The 4 inch kit comes with a t block the stock hose connects to and the new hose goes to the master cylinder from that block. So, I am just looking for pictures to see how someone installed theirs.
Lloydz TT intake
Lloydz ATS wheel
RPW Big Slash
Lloydz IAV
Ness Fly Bars
ISO grips
Victory HID
chaz7887 is offline
post #7 of 11 (permalink) Old 03-03-2014, 08:52 PM
Gotcha, Along the lower frame rail there is 3 tabs holding the stock brake line to the bike, loosen all 3 bolts and pull rearward and tighten back up.....
post #8 of 11 (permalink) Old 03-03-2014, 09:00 PM Thread Starter
Here is kind of what I am dealing with.
Lloydz TT intake
Lloydz ATS wheel
RPW Big Slash
Lloydz IAV
Ness Fly Bars
ISO grips
Victory HID
chaz7887 is offline
post #9 of 11 (permalink) Old 03-03-2014, 09:10 PM
Can you rotate the block so that the brake line is facing the inside?
post #10 of 11 (permalink) Old 03-03-2014, 09:16 PM Thread Starter
I'll just work on it tomorrow and hope to find a happy median.
Lloydz TT intake
Lloydz ATS wheel
RPW Big Slash
Lloydz IAV
Ness Fly Bars
ISO grips
Victory HID
chaz7887 is offline
