Clutch cable broke - Victory Forums - Victory Motorcycle Forum
post #1 of 23 (permalink) Old 04-21-2014, 10:36 AM Thread Starter
Gcash's Avatar
Default Clutch cable broke
Well boys I was out for maybe 5 min when I felt a big snap and realized right away what had happened. I have a Barnett steel cable but it still snapped sucks big time! So now I've decided to go hydraulic, I have the unit ordered up and will post pics of the install when it happens!
Gcash is offline
post #2 of 23 (permalink) Old 04-21-2014, 10:49 AM
Weeds's Avatar
What bike do you have...
2013 XCT, Red,
Tri Ovals, S1 Package, Accel 8.8 Wires,Yellow.
Wheel @ +4, Kuryakyn Shift/Brake Pegs, o2s Disabled.
Utopia Backrest. KewlMetal Heal Shifter with Kuryakyn pegs ..
Lubrication Provided By Amsoil..
Even duct tape can't fix stupid....but it will muffle the sound
Weeds is offline
post #3 of 23 (permalink) Old 04-21-2014, 10:51 AM Thread Starter
Gcash's Avatar
I have a 05 Hammer
Gcash is offline
post #4 of 23 (permalink) Old 04-21-2014, 02:00 PM
Victory being cheap doesn't want to have a good life long clutch perch and lever.
You have to lube it often to prevent breakage
post #5 of 23 (permalink) Old 04-21-2014, 08:05 PM
Konga63's Avatar
Hey G,
I was wondering if you would do me a favor. When you get your stock clutch lever off, would you mind looking at the area where the cable attaches to the lever and tell me/fellow forum members et all if there are any edges or other types or irregularities there from the casting process? I ask this because one of the first things I did was pull my clutch lever and took a gander. I found several sharp casting edges/bumps/deformations which I immediately filed smooth. Wondering about these clutch cables breaking and why?
2007 Ness Jackpot
Konga63 is offline
post #6 of 23 (permalink) Old 04-21-2014, 09:00 PM
KingpinRider's Avatar
Got 5,000 out of my first one. Up to 13,000 on the new and improved along with a Save-Ur-Ride cable in my saddlebag.
2008 Vision Tour Premium - Midnight Cherry
2008 Kingpin Tour - Black & Chrome (SOLD 10/14)
KingpinRider is offline
post #7 of 23 (permalink) Old 04-21-2014, 09:04 PM
Motorbikerx's Avatar
Originally Posted by Konga63 View Post
Hey G,
Well according to that police vid on YouTube that I followed, regular cleaning and lubing of the cable ends is the key.
I used a moly cam lube on mine but would prefer moly grease when I can get hold of a small tube of it.
Was your cable ends cleaned and lubed every oil change?
My clutch is very heavy to pull in, a lot more than any other Vic clutch I've felt.
The cable is nice and free itself when I disconnect it to lube the ends so it must be inside the clutch itself.
Its a bit of a worry cos it must be hard on the cable.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #8 of 23 (permalink) Old 04-22-2014, 01:26 AM Thread Starter
Gcash's Avatar
Hey G,
Will do Konga
Gcash is offline
post #9 of 23 (permalink) Old 04-22-2014, 04:03 AM
Originally Posted by Gcash View Post
Will do Konga
Im in the market for a clutch lever after breaking the end off mine when the bike fell over a few weeks ago, Araldited the broken tip back on but it looks a bit daggy.
Wanna sell me your old lever?
hate to think what Vic wants for a new one here in Aust.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #10 of 23 (permalink) Old 04-22-2014, 07:50 AM
MTVic's Avatar
Did it snap at hand lever or at the bottom?
If it snapped at the bottom, hydraulic clutch may not fix it, it still uses a push rod/cable at bottom. Probably stronger though.
That said... I'm moving to Hydraulic too next week.
Mike
FORMERLY 2012 Black XC Tour
2016 Honda NM4
2014 Honda CTX 700 dct
MTVic is offline
