Running rough when cold after tune up - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 05-06-2014, 06:49 AM Thread Starter
Default Running rough when cold after tune up
A couple weeks ago I changed the oil, plugs, and a k&n drop in filter to get the bike ready for summer, and since then the bike continuously seems to hate running while cold more and more. I hate letting the bike sit in front of the house warming up especially during the early mornings due to the (unknown brand) of slip-ons that im sure are much louder than the neighbors appreciate.
When cold:
Rough idle, jerkiness, once in a while stall, backfiring.
When warm; bike runs fine minus occasional backfire.
Any ideas what would cause all this?
06hammering is offline
post #2 of 15 (permalink) Old 05-06-2014, 06:50 AM Thread Starter
2006 hammer, 15,000 miles btw.
post #3 of 15 (permalink) Old 05-06-2014, 12:21 PM
Not sure why when cold its running rough and hot its ok.
Check your plug wires at coil and at plugs. Make sure there on all the way.
Check for a vacuum leaks.
Tells us more
post #4 of 15 (permalink) Old 05-06-2014, 12:28 PM
LILMAGS500's Avatar
Make sure your battery is a good one and fully charged
Be sure battery connections are as tight as possible
Check your plugs and make sure you have the proper gap , and that the porcelain is not cracked
Make sure your are using the correct plug #
Check spark plug wires , sometimes removing them may cause a bad connection at the metal clip that actually attaches to the plug , be sure they are secure
Be sure you didn't inadvertently disconnect any vacuum hoses , or tweak anything that may have caused a vacuum leak
If it was running fine before you did what you did , there in lies the rub
Good luck
LILMAGS500 is offline
post #5 of 15 (permalink) Old 05-06-2014, 08:02 PM Thread Starter
After about 9 hours of sitting battery was still at 12.98v.
oil is right at full line.
Couldnt hear or feel any vacuum leak but havent removed the tank yet but this seems like my best bet.
Also i increased idle to 1000 but didnt help.
Both plugs did have a slight black dusting around the electrode i assume this is normal? All else was tight and appeared fine
post #6 of 15 (permalink) Old 05-06-2014, 08:05 PM Thread Starter
Could the new filter have made the already lean issue this much more noticable particularly when cold? Might be looking at lloydz tuner sooner than i thought
post #7 of 15 (permalink) Old 05-06-2014, 08:19 PM
vindex1963's Avatar
I would have to think just a filter wouldn't do that unless you were right on the edge. Do you have the reflash with the aftermarket exhaust? Put the old filter back in and see.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #8 of 15 (permalink) Old 05-06-2014, 08:34 PM
p.hunt's Avatar
If it was the K&N with a new vented side cover then that's your problem. Put the original side cover back on leave the K&N in and it should solve it.
2012 Vision - in process of converting to Cross Country rear end and bags
Lloyd's -Filter-Timing wheel-Adjustable Intake-Throttle ring
PCV5
Home built 2 into 1 pipe with dummy pipe on left looks stock
p.hunt is offline
post #9 of 15 (permalink) Old 05-07-2014, 01:38 AM Thread Starter
Its just a k&n rectangle filter inside the factory air box, not a side mount. I no longer have the original filter.
Also, when I bought the bike it already had the slip ons, which was the only mod. Dont believe its been tuned. I would simply get a tuner, but i dont want to dump fuel etc if that isnt the root cause
post #10 of 15 (permalink) Old 05-07-2014, 03:56 AM
LILMAGS500's Avatar
Your engine will run richer when its cold , lean doesn't sound like your issue ......
