Engine knock! Freaking out! - Victory Forums - Victory Motorcycle Forum
post #1 of 33 (permalink) Old 05-07-2014, 09:00 AM Thread Starter
Dr. Derp's Avatar
Default Engine knock! Freaking out!
Sounds like piston slap in the front cylinder. Looked down both cylinders with a bore scope...rear cylinder is nice and shinny, front is dark and has vertical lines all over it. I guess I'll know the truth tomorrow...taking it to The Vic Shop. Hope I don't need a full rebuild.
05 Hammer
104" built by The Vic Shop
Lloyds pistons and heads
PMRT intake
438 Cams
Bassani 2-1
PC III USB
All kinds of other cool stuffs
130 hp
125 ft lbs o torque
Twice as much money into it than what it's worth!
Dr. Derp is offline
post #2 of 33 (permalink) Old 05-07-2014, 09:15 AM
ammo_umb's Avatar
Has it been ran recently? Does it clear up after idling for a few minutes? Does it make the same noise when started after it's warmed up?
Retired USAF, IYAAYAS!
ammo_umb is offline
post #3 of 33 (permalink) Old 05-07-2014, 09:20 AM Thread Starter
Dr. Derp's Avatar
Put about 200 miles on it this spring. It's loudest when first started, but never seems to really go away. I can hear it when rolling on the throttle with a helmet on.
05 Hammer
PMRT intake
438 Cams
Bassani 2-1
PC III USB
130 hp
125 ft lbs o torque
Dr. Derp is offline
post #4 of 33 (permalink) Old 05-07-2014, 09:21 AM
LILMAGS500's Avatar
I read this stuff and it makes my stomach turn , good luck with it ...
LILMAGS500 is offline
post #5 of 33 (permalink) Old 05-07-2014, 09:27 AM Thread Starter
Dr. Derp's Avatar
Thanks Mags. Just so everyone knows the history...
05 Hammer, 19,000 miles. Purchased bike in winter, couldn't test ride it.
Gave bike a full tune up (plugs, wires, fresh fuel, intake boot, cleaned throttle body, oil change). Bike was clean, but not maintained. Didn't notice any odd noises at first...progressively got louder the more I rode it.
05 Hammer
PMRT intake
438 Cams
Bassani 2-1
PC III USB
130 hp
125 ft lbs o torque
Dr. Derp is offline
post #6 of 33 (permalink) Old 05-07-2014, 09:28 AM
ammo_umb's Avatar
It sounds like your lash adjusters on the valves are bleeding down. While it's making the noise try holding a piece of pipe against your cylinders and valve covers and putting your ear on the other end. If the adjusters are the issue you'll hear a lot more noise in one or both valve covers than in the cylinders.
My bike did the same for a couple of winters but went away when I changed back to syn/dyno blend oil. Syn oil seems to drain from the adjusters faster than dyno.
Added: also listen around the exhaust ports - it could be something as simple as exhaust gaskets.
ammo_umb is offline
post #7 of 33 (permalink) Old 05-07-2014, 09:50 AM Thread Starter
Dr. Derp's Avatar
Exhaust gaskets are new...just put new exhaust on it. I'll just wait and see what the pro says tomorrow!
05 Hammer
PMRT intake
438 Cams
Bassani 2-1
PC III USB
130 hp
125 ft lbs o torque
Dr. Derp is offline
post #8 of 33 (permalink) Old 05-07-2014, 09:53 AM
LILMAGS500's Avatar
Please keep us informed , Dr.
post #9 of 33 (permalink) Old 05-07-2014, 09:56 AM Thread Starter
Dr. Derp's Avatar
Will do. On the bright side, if it does need a rebuild, no reason to stay stock!
05 Hammer
PMRT intake
438 Cams
Bassani 2-1
PC III USB
130 hp
125 ft lbs o torque
Dr. Derp is offline
post #10 of 33 (permalink) Old 05-07-2014, 04:03 PM
SilentUnicorn's Avatar
I will put my money on a broken ring....
m
'12 Vegas, 78 Bonneville, 69 BSA project.
SilentUnicorn is offline
