13' Hammer 8 Ball Lowered 1" Belt Tension - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 06-06-2014, 09:07 AM Thread Starter
Default 13' Hammer 8 Ball Lowered 1" Belt Tension
Morning
Is the belt tension increase or decreased or does it remain the same? I would think it would have to be decreased as it "seems" like the belt is a tad tighter.
2013 Victory Hammer 8-Ball
mobgma is offline
post #2 of 11 (permalink) Old 06-06-2014, 10:11 AM
You lower the bike the belt gets tighter.
You have to readjust the belt for sure.
post #3 of 11 (permalink) Old 06-06-2014, 10:28 AM
LILMAGS500's Avatar
Mobs , The 8Ball models run their belts tighter then the other models ... You should have 6mm of deflection at the belts tightest point measured at the center between the two pulleys , with ten LBS of up and down force on the belt . You can get a good quality tension gauge for 22.00 to 29.00 or so to measure this force .
LILMAGS500 is offline
post #4 of 11 (permalink) Old 06-06-2014, 10:34 AM Thread Starter
I should probably loosen it.
mobgma is offline
post #5 of 11 (permalink) Old 06-06-2014, 01:27 PM
Default 6mm TIGHT!
on my 13 hammer with 1/2 inch longer penske shock i set the belt about 3/8 @ 10 lb rear wheel up in the air, bike on the ground it felt VERY tight!! went to 3/4" and seems decent. my first vic so i am learning. belt was prolly 1 1/4" when i got the bike at almost a thousand miles. i am open to suggestions.
rodhotter is offline
post #6 of 11 (permalink) Old 06-06-2014, 01:42 PM
LILMAGS500's Avatar
Manual states 6mm on 8Ball models and 12mm on all others .... I set mine at 6mm , with no problems . You need to remember to rotate your wheel until the belt is at its tightest point and make your adjustment from there . Or you may be running too tight for sure .
post #7 of 11 (permalink) Old 06-06-2014, 01:44 PM
LILMAGS500's Avatar
Your shock being longer may need you to do a custom adjustment , with the geometry being different and such ... I would rather a little loose then too tight of course ....
post #8 of 11 (permalink) Old 06-06-2014, 07:38 PM Thread Starter
Now my problem is now that I lowered it 1" my lift doesn't slide underneath the bike any more.
mobgma is offline
post #9 of 11 (permalink) Old 06-12-2014, 11:54 PM
I took the wheels off my lift, and it slides back under it now
later
Tachdriver is offline
post #10 of 11 (permalink) Old 06-13-2014, 11:03 AM
mobgma
run the bike up on a 2x4 that should do it
