Judge Fuel Reserve Light - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 10-12-2014, 09:06 AM Thread Starter
RSA
Default Judge Fuel Reserve Light
Curious if other Judge Owners have experienced an issue with an inaccurate fuel reserve light? I.e., the tank holds 4.7 ga per the specs, and the fuel reserve light is supposed to come on when there is approximately 1 ga of fuel remaining. Thus far my light has been coming on between .3-.4 of fuel remaining. This would translate to about 15 mi. before running out of gas.
I know that the reserve is only an approximate and I completely understand that, but I would expect approximate to be in the range of 1.3 Ė 0.7 fuel remaining, and not the .3-.4 gallons remaining that I've experienced.
The reason Iím asking is because I have a í14 Judge and the dealership has offered to replace the assembly that includes the fuel sensor under warranty. However, if the light coming on with little fuel left is common on the Judge, I canít see replacing the part if the new sensor will do the same thing.
Curious on experiences from other Judge owners, and if anyone that has experienced the same issue has resolved the problem by swapping out the fuel assembly?
Thanks, and I do use the odometer to know when Iím running low, but while the bike is still under warranty I've been testing features so that I can correct any problems now.
Rob
RSA is offline
post #2 of 11 (permalink) Old 10-12-2014, 12:10 PM
Judge Redd's Avatar
Part of this is misreading the manual. I did the same thing.
It says LESS THAN 1 gallon. Nice and cryptic huh?
Thus I ended up coasting into a gas station around 15 or 20 miles later. So it's definitely less than a gallon- I would assume that there probably is at least a small measure of fuel that would be inaccessible if the tank was empty enough. I will say that I doubt replacing the assembly will make any difference. The range after the light stays on will vary depending on what type of riding is going on at the time- just like at any other fuel level status. Suffice to say- I do not push my luck much with the light on.
I think I did go about 18 miles once this past summer. It was just one of those times where premium was about .35 cheaper at the Costco a few hundred yards away from my house than anywhere else. I also had a backup available if I drained it- so I went for it. I did make it that time- with no sputtering at all. It took 4.9## to fill it to the neck. (who knows how companies arrive at their published specs)
Anyway- Personally I wouldn't bother with allowing someone to tear that down. Who knows what they might screw up. You have a 50/50 shot that the assigned tech has any significant Victory knowledge unless your dealer has no other brands..(unlikely) Just mind that light until it's broken in well. Keep a good track of how your range varies based on the riding and pretty soon it's just as good as a gauge. In fact- I will dare say better based on some of the posts here regarding how bad the real gauges are. (Victory is not alone in this)
2014 Judge(Havasu Red) PC-V - ATS(+4) - RPW Boom Sticks - HOHVM1-DR cams - Torque Tubes (dyno sheet) 1/4 turn throttle - OPT7 LED headlight kit - OEM bags, backrest, and W/S
Judge Redd is offline
post #3 of 11 (permalink) Old 10-13-2014, 10:14 AM
ptc
ptc's Avatar
Wish I had your problem.... I cant get my light to go off ANYTIME!
And its really bright at night!
2011 Custom "Hammered XR"
http://streetbikeusa.blogspot.com/
BBob- "We all share the same wind regardless of the t-shirts we wear"
ptc is offline
post #4 of 11 (permalink) Old 10-13-2014, 10:23 AM
Motorbikerx's Avatar
there's roughly 3 litres left when the light comes on.
A US Gallon is 3.9 litres
An Imperial Gallon is 4.5 litres
when the light comes on its best to start looking for fuel.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is online now
post #5 of 11 (permalink) Old 10-13-2014, 04:57 PM Thread Starter
RSA
Appreciate all the feedback. Seems like my issue is close to Judge Redd's experiences in that at max I can go 15-20 miles before running out of gas, which unfortunately is far less than a gallon of gas.
I'd still welcome any other insights from other Judge riders.
Thanks,
Rob
RSA is offline
post #6 of 11 (permalink) Old 10-14-2014, 08:08 AM
Judge Redd's Avatar
Just over a year into it and just over 10k miles-- Typical lows and highs before the light comes on:
Low end: 170 miles
High end: about 210- the highest that I remember was 218.
Probably like most- my riding will involve a variety of conditions. I expect the light right around 180 now.
post #7 of 11 (permalink) Old 10-14-2014, 09:01 AM
takes a while to get a solid light too, mine will start to flicker on then go out if I accelerate as more fuel is forced back over the pump, usually by 240k which is 150 miles its on.
Depends how I'm riding.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #8 of 11 (permalink) Old 12-02-2014, 01:09 PM
Why cant they put a proper gauge on.
2008 Suzuki B King,2010 Vegas 8 Ball,2006 BMW Z4.
goon is offline
post #9 of 11 (permalink) Old 12-02-2014, 01:54 PM
Judge Redd's Avatar
A valid gripe IF they could be bothered to build a decent gauge to begin with.
The bikes with "proper" gauges are pretty bad in their own way. 5.8 gallon tank for a XC but several people on here say they often cannot pump in 4 gallons back in with the needle on the "E" ? If that's true- there's not a big benefit to having one..
Victory is not the only one, either. Dad's FJR- digital gauge- will stay full for an extended period, then drop like a sack of potatoes. I'm sure owners of other brands have similar stories. I guess the silver lining to the Vic's calibration is at least it's reading lower than it actually is, and not reverse..
post #10 of 11 (permalink) Old 12-02-2014, 08:55 PM
any thing below a gallon your fuel pump is getting hot. You get it hot enough and you'll be need a new one
