Front belt cover removal - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 08-18-2014, 11:14 PM Thread Starter
Default Front belt cover removal
In order to remove all the bolts holding on the front belt cover do I need to drop the exhaust pipes?
I ask only because I have something rubbing the top of my drive belt leaving a slite mark on both sides, and inspecting the drive belt rear cover I can see scratch marks on the bottom (facing belt) side.
I can not see anything touching the drive belt, so my guess is it has to be in the front belt cover.
redfromwi is offline
post #2 of 8 (permalink) Old 08-19-2014, 06:42 AM
ByteN2it's Avatar
I've pulled mine off without having to move anything-You need to use a ball end allen wrench and cut a regular one down to fit between the bottom bolt & pipe-that and a little patience and it can be done. Put some masking tape on the face so you don't scratch the chrome on the cover on the exhaust pipe clamp when you take the cover off.
ByteN2it is offline
post #3 of 8 (permalink) Old 08-19-2014, 09:40 AM
Motorbikerx's Avatar
I got the same sorta marks on mine (Vegas Low) but I don't worry about it.
interested to know what you find though
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 8 (permalink) Old 08-19-2014, 11:27 AM
Lowering the bike will make the belt rub on the front cover
post #5 of 8 (permalink) Old 08-19-2014, 01:08 PM
I lowered my wifes Boardwalk 1.5 inchs and the belt made a zinging noise so I removed the rear belt cover and the noise stopped.
Kevin & Lori
:) Blue Ridge Ga. 2011 Vision , 2016 Magnum , 2011 Kingpin , 2016 Kaw vulcan s
1ofeach is offline
post #6 of 8 (permalink) Old 08-19-2014, 03:49 PM Thread Starter
Bike is still stock except for a Batwing faring, saddle bags only holding chaps and tool kit in one and leather jacket in the other, luggage rack bag holds gloves, glasses, map, cleaning rags.
only thing different on the day I noticed the marks was a 40 + mile ride at 80 + mph.
post #7 of 8 (permalink) Old 08-19-2014, 03:57 PM
If you haven't already done it , remove the rear belt cover and see if that helps. If not then try to grind down the mount hole on the front cover that VJ showed a pic of , that seems to be a frequent problem.
Kevin & Lori
1ofeach is offline
post #8 of 8 (permalink) Old 08-19-2014, 10:49 PM Thread Starter
Will be taking a look see this coming weekend, as it is the first day I will have any time to work on the bike.
