rear shock pre load adjustment. - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 08-25-2014, 04:14 PM Thread Starter
deepstuff's Avatar
Question rear shock pre load adjustment.
Hi,
* * *Whats the general concensus. *Are people adjusting rear shock preload according to measurement in mannual or are you guys adjusting stiffer for performance? *
* I'm riding now with about 3/4" more ground clearance than manual recommends. *Will I se much difference if I make the adjustment?
Thanks*
2008 Kingpin Premium
Newfoundland,
Canada
deepstuff is offline
post #2 of 10 (permalink) Old 08-25-2014, 06:07 PM
blkb3tty's Avatar
I adjusted mine for 2up riding as the wife and I ride on the weekends and just leave it there durring the week when riding back and forth to work.
'12 Vegas 8-Ball
blkb3tty is offline
post #3 of 10 (permalink) Old 08-25-2014, 06:22 PM
Pheonix's Avatar
I go by the owners manual. I have a piece of angle iron cut JUST under the highest setting. I put painters tape on it and place it under proper spot on frame. sit on bike and adjust shock where it barely touches when loaded with my weight. Then if I go camping at a rally, it drops to JUST above the lowest measurement with the added weight of my gear. That way it always stays in the "sweet spot" operating range of the shock. Always worked great for me.
2011 Kingpin - Scarlett
Stage I Pipes with Thunder Monsters & NO Catcons
Ness Laydown Plate Holder with Custom Dynamics LED Plate Frame
Custom Ness Engine Covers
V92C Floorboards with NON-LOW Mounts
Ness Ram-Air
PC-V
Lloydz Timing Wheel
Dyno Tuned by 804 Motor Sports
97.26 HP / 110.42 # for now...
Pheonix is offline
post #4 of 10 (permalink) Old 08-25-2014, 09:17 PM
on my 13 hammer with a similar if not the same cheap shock i found a penske to be a solution. very easy to adj the preload on the bike unlike the OE shock. bike rode very hard with OE setup but much better with the penske. thats saying a lot as the OE 250-40 only looks good but rides hard!
rodhotter is offline
post #5 of 10 (permalink) Old 09-03-2014, 07:53 AM Thread Starter
deepstuff's Avatar
Question
I adjusted my preload yesterday. I'm 180lbs. In order to get the recommended ground clearance I had to almost totally back off adjustment nut. Backed it off 7-turns. Only just enough thread left for the lock nut. Is this normal?
Newfoundland,
Canada
post #6 of 10 (permalink) Old 09-03-2014, 08:01 AM
Motorbikerx's Avatar
Dont sound like it to me...
I measure nothing, just wound it down harder two full turns, rode pretty much the same, not noticeably harder, still bottoms the sides of the rear 180 tyre up inside the rear fender on extreme bumps two-up.
Gonna try winding her down another two turns next time I'm over at Burleigh Bars as the owner there has the correct spanners.
No matter what the ground clearance is theyre gonna scrape
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #7 of 10 (permalink) Old 09-03-2014, 08:27 AM
Default OE compromizes
suspensions can't work for everyone due to different weights + riding preferences. the bean counters step in as well, quality suspension is costly for sure. only way is if its built for YOU or as my Bitubo's on my bonneville, they have 3, i believe weight setups off the shelf + with quality parts hit it well. if your comfortable with your ride at that adjustment thats fine, otherwise save some bucks + get a built for YOU Penske shock. well worth it especially if your keeping the bike a while. some tires help as well as dunlops + bridgestones are said to be harder riding compared to others
post #8 of 10 (permalink) Old 09-03-2014, 08:54 AM Thread Starter
deepstuff's Avatar
I'm not complaining about the ride. It is a little softer now. I mostly do 1-up. Just wonder if for a 180 lbs rider it's normal to be so near the adjustment limit to be within spec on ground clearance?
Newfoundland,
Canada
post #9 of 10 (permalink) Old 09-03-2014, 09:03 AM
Remember that you want to preload a spring no more than 30-40% of it's length. More preload and you're going to screw up the ride as the spring won't be able to do its job properly. If you need to crank the preload down more than 30-40% you need a heavier spring (more spring rate).
biggziff is offline
post #10 of 10 (permalink) Old 09-04-2014, 06:04 AM Thread Starter
deepstuff's Avatar
No worries about cranking it down. Mine is all the way up to get ground clearance spec in manual.
Newfoundland,
Canada
