Kingpin Belt Tension Check - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 03-29-2012, 12:00 PM Thread Starter
Default Kingpin Belt Tension Check
My 2010 Pin measures almost 1 inch slack when cold, manual states 12mm (1/2 in) slack measured half way between the sprockets, heard that when engine is hot belt tightens up so question is should the belt be checked with the engine hot but belt cooled down a bit or check when cold?
Also, what size socket fits on the adjuster nut, none of mine fit.
Scott
skooter is offline
post #2 of 3 (permalink) Old 03-29-2012, 12:51 PM
half_crazy's Avatar
13mm deep socket is what I use.
You should adjust belt tension with the bike cold and the suspension topped out. The spec is center between the pulleys and 10 lbs of force upward on the belt. You can buy a gauge for that from Vic.
2006 Victory Kingpin
half_crazy is offline
post #3 of 3 (permalink) Old 04-17-2012, 12:26 PM
KingpinRider's Avatar
Skooter, is your belt chirping with the extra 1/2" of slack? Just curious. I was told that belt tension or lack thereof may cause belt chirping.
KingpinRider is offline
