Please help, not sure what topic to put. - Victory Forums - Victory Motorcycle Forum
post #1 of 16 (permalink) Old 04-23-2015, 06:40 PM Thread Starter
Jonnyboy's Avatar
Default Please help, not sure what topic to put.
So I was on a ride the other day, left the breakfast place.....bike stalled. Started fine, rode up the hill a ways.....started trying to die and backfire. Mt buddy bringing up the rear said it was running way rich, and my taillight went out when the bike starting dying out. I found a loose battery cable, cleaned and tightened that. Bike still stalled out a couple times. Do you think a TPS reset is needed because of the battery issue?
Sorry for the long story, just want you to know the details. 05 kingpin
Jonnyboy is offline
post #2 of 16 (permalink) Old 04-24-2015, 10:18 AM
epson390's Avatar
My buddy had the exact same issues with his harley, bike would try and stall/die, running poor/rich. Lights were acting up. Turns out the battery had shit the bed even though it would start. Try a new battery or swapping one from your buddy's to try it.
2014 XC - Pearl White - 16" Ape Hangers, LED Headlight, Lloydz Timing Gear @ +4, SharkHonker Exhaust, PCV, 1/4" Turn Throttle Ring, Hard Lowers, Keyless Ignition, Lloyd's Intake, Klockwerk Shield
epson390 is offline
post #3 of 16 (permalink) Old 04-24-2015, 10:21 AM
Motorbikerx's Avatar
wouldnt hurt to clean your throttle bodies too
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 16 (permalink) Old 04-24-2015, 11:01 AM
put battery on charger and after it has a full charge go get a load test on it. I'm thinking its the original battery and its done for.
Clean the throttle should be done once a year I'm thinking
look for cracks in the rubber plugs and hoses
https://www.youtube.com/watch?v=QOeH1UgzhQc
post #5 of 16 (permalink) Old 04-25-2015, 08:15 PM
bassaholic's Avatar
The battery is a good place to start. According to the manual, the battery should read no less than 12.5V when the motor is off. It wouldn't hurt to charge it and then check it with a meter. If the reading starts dropping, it's toast.
When my original battery recently died on me I could get the motor to turn over sometimes and then another the lights would come on then die.
I replaced the battery with a Chrome battery. It was inexpensive and has been working well for me.
2009 Kingpin Low:
  • Mustang seat w/ driver's backrest
  • Swept exhaust
  • Stage 1 flash and high-flow filter
  • Victory saddlebags
  • Guardian bell
  • Lindby highway bars
  • ATS @ +4 deg
2005 Honda Shadow Spirit - Sold
bassaholic is offline
post #6 of 16 (permalink) Old 06-05-2015, 10:06 PM Thread Starter
Jonnyboy's Avatar
I just put a new battery in about 2 months ago. Throttle bodies are clean, air filter is clean, battery connections are clean and tight. Called dynojet, they said to do a reset on the PC3 and reload the map, still runs like crap. It has been running fine for about a year, no changes made.....and now it stutters and stalls randomly. I even tried a different map, no luck.
I'm really missing my Honda right now, never an issue with that bike.
Jonnyboy is offline
post #7 of 16 (permalink) Old 06-05-2015, 10:22 PM
Well you could plug it into the computer at the dealership and it should come up with the error....or
Take it to a reputable tuner and have it dynoed
Or..buy that Honda back
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #8 of 16 (permalink) Old 06-05-2015, 10:55 PM
slickvic's Avatar
You have an electrical gremlin somewhere. Check all relays and the circuit breaker. Check your grounds. Any relays that come apart lokk for moisture, clean and use dielectric grease. Watch when you wash your bike and where you spray water. Time to get familiar with your Victory. Do you have a service manual? Good luck.
slickvic is offline
post #9 of 16 (permalink) Old 06-06-2015, 01:13 AM
Like he said^^^^ maybe the famous "Chinese" circuit braker syndrome????
It's definitely bit others on here. Lights going out and all...
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #10 of 16 (permalink) Old 06-06-2015, 03:39 AM
DirtyDan's Avatar
Wouldn't be the first time a power commander shit the bed either.
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
