Headlight out + Check Engine light on = Bad Regulator/Rectifier - Victory Forums - Victory Motorcycle Forum
post #1 of 2 (permalink) Old 08-12-2012, 11:23 AM Thread Starter
KingpinRider's Avatar
Default Headlight out + Check Engine light on = Bad Regulator/Rectifier
I replaced my headlight once with under 6000 miles. Headlight was out again and Check Engine light came on. Bike seemed to run fine. Service code was "overvoltage", some 18V out of regulator/rectifier.
Just a heads up to 2008 Kingpin owners. Sucks when you're on a road trip and in the middle of nowhere and Check Engine light comes on. Thankfully, the high beam light worked to get me home in the dark after dinner.
Have your regulator/rectifier checked if your headlight has ever gone out.
KingpinRider is offline
post #2 of 2 (permalink) Old 08-12-2012, 01:47 PM
CrossRoads's Avatar
Uhhh, glad you figured it out. If your battery did not get replaced at this time, keep an eye on it. Overcharging it usually reduces its life drastically, so except it to be going soon.
CrossRoads is offline
