Front end noise when leaning ? - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 08-29-2012, 07:13 AM Thread Starter
Default Front end noise when leaning ?
Anyone else have a whir/whine/buzz noise when you lean into a corner? It sounds like it comes from the front wheel/brake area but of course its hard to pin-point it at speed. It is louder when leaning left than right, and it is a constant sound.
I've also got a bit of break "rub" when I push the bike, like when parking or moving it in the garage. I never heard that on my Yamaha, so I'm not sure if that is normal for the KP ?
I've got 22k miles, not sure when the previous owner changed break pads. I might just do that regardless.
2013 Victory Vision in black
2008 Victory Kingpin Tour - traded
2000 Yamaha VStar 650 - traded
Cruising the coulees in God's Country (Western WI)
ljurgens is offline
post #2 of 12 (permalink) Old 08-29-2012, 11:16 AM
Bad wheel bearings. Have a buddy hold the bars and see if you can wiggle the front wheel.
Check axle to see if its tight.
Grab a hold of the break rotor and see if it wiggles. If so floaters are bad.
Put a straight edge on rotor and see if its flat. Check all the way around.
Check front fender bolts.
You should get a little or slight break pad rub sound in the garage.
What have you done to the front of the bike.
post #3 of 12 (permalink) Old 08-29-2012, 11:31 AM
Bad tire can also cause the issue. A loose axle may also, allowing the rotor to rub the pads unevenly...
2011 Silver/black Vision, Ness Big Honkers, Ness Twin Sucker, PC-V w/AT, Lloydz VM1-DR cams, Lloydz Adj Intake, Lloydz Variable Timing Wheel.
2006 110" (133hp/142tq) +nitrous Kingpin (sold)
Gunslinger is offline
post #4 of 12 (permalink) Old 08-29-2012, 11:39 AM Thread Starter
Haven't done anything to the front of the bike since I bought it.
It does have Lindby bars and Victory lowers on it.
I had the bike up on a jack and had my son hold the bars and I tried to wiggle the wheel, thinking it could be the in the bearings. I didn't feel any wiggle. But since I only get the sounds when leaned over and that puts pressure on the bearing (I would assume), it could still be that.
I'll go through the checks you described tomorrow and see what I find.
Edit: Tires are pretty new, and "look" really good.
ljurgens is offline
post #5 of 12 (permalink) Old 08-29-2012, 12:03 PM
I have seen brand new tires that were defective. No visual way to tell
post #6 of 12 (permalink) Old 08-29-2012, 12:50 PM
DrIsotope's Avatar
I have a tad of brake rub when parking in the garage when the wheel is turned a tad but nothing major. My Yamaha did it as well.
09' Kingpin Low
Stage 1 Upgrade w/ X-Bow Pipes - Complete
Keyless Ignition - Coming Soon
Slanted License Plate - Coming Soon
Neon Green Spark Wires - Coming Soon
DrIsotope is offline
post #7 of 12 (permalink) Old 08-29-2012, 04:55 PM
So you have new tire and now you have sound. Bet your tire is a E3 and what your hearing is the tire groves growling
post #8 of 12 (permalink) Old 08-29-2012, 09:18 PM
KingpinRider's Avatar
I hear the same thing on my '08 Kingpin with 10K mi. Only notice leaning left at about 30mph. Interested in learning your solution.
2008 Vision Tour Premium - Midnight Cherry
2008 Kingpin Tour - Black & Chrome (SOLD 10/14)
KingpinRider is offline
post #9 of 12 (permalink) Old 08-29-2012, 09:26 PM Thread Starter
Not a new tire, hadn't heard it when I first bought the bike. Had 19k miles when I bought it end of May, I've got 22.5k miles now and I've been hearing it for the last 1k miles or so.
Mostly left, and much more faint to the right.
ljurgens is offline
post #10 of 12 (permalink) Old 08-30-2012, 08:54 AM
handyhoward's Avatar
Not to worry... the brake pads are most likely rubbing a little... just be sure to have an 1/8" of pad and your good to go.
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
handyhoward is offline
