Need clutch pedal help - Victory Forums - Victory Motorcycle Forum
post #1 of 27 (permalink) Old 07-03-2015, 07:26 AM Thread Starter
Default Need clutch pedal help
I would like to move my clutch pedal back (controls are in the farthest back position already) and cannot find a replacement pedal that will give me that advantage. Any ideas?
MsQueen is offline
post #2 of 27 (permalink) Old 07-03-2015, 07:40 AM
kevinx's Avatar
Clutch pedal??
kevinx is offline
post #3 of 27 (permalink) Old 07-03-2015, 07:57 AM
LILMAGS500's Avatar
Originally Posted by kevinx View Post
Clutch pedal??
Do you think she means shift lever ?
LILMAGS500 is offline
post #4 of 27 (permalink) Old 07-03-2015, 09:44 AM Thread Starter
Hi. Yes I mean shift pedal and I am a woman. Thx
MsQueen is offline
post #5 of 27 (permalink) Old 07-03-2015, 09:58 AM
LILMAGS500's Avatar
My apologies . I have not seen shorter shift / brake levers available as of yet , Just wondering you must be tiny , have you lowered your bike or had the seat modified to get you closer to the ground . If reaching the levers is difficult / uncomfy , touching the ground must be challenging too .
post #6 of 27 (permalink) Old 07-03-2015, 10:00 AM
LILMAGS500's Avatar
You may want to email Witch Doctors and see if he could make you a custom set , or even a modified set of pegs that could get them closer to you ....
post #7 of 27 (permalink) Old 07-03-2015, 10:01 AM
LILMAGS500's Avatar
I see you are from MA , me too !
post #8 of 27 (permalink) Old 07-03-2015, 10:03 AM
Motorbikerx's Avatar
post a pic of you sitting on the bike and we'll see what we can work out for you.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #9 of 27 (permalink) Old 07-03-2015, 10:36 AM
You can go to a saddle customizer and have him modify your saddle to move you forward. If you have difficulty reaching the shifter, you must also have too much of a reach to the bars. Having the seat move you toward them should give you what you want--and a more comfortable saddle too.
You'll have to forgive KevinX, he's been stuck in his shop and hasn't seen a woman in decades. So he doesn't know how they think. I'm here to help you out. Out of what is up to you.
RICZ is online now
post #10 of 27 (permalink) Old 07-03-2015, 10:40 AM
LILMAGS500's Avatar
As true as your statement may be Ric , I think its me she has to forgive . I will fix that post now ...
