Bottoming out problem - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 25 (permalink) Old 07-10-2015, 08:04 PM Thread Starter
Default Bottoming out problem
Hello again,
I have a new (used) 2009 Kingpin and I had them swap out the seat to a lower seat and they also used a lowering kit so I can reach the ground. I am now bottoming out over some bumps (not major ones) and they said not much can be done about this. I don't like this sound or feeling so they said they will check the adjustment on the mono shock at the rear. Does anyone have any suggestions on how to correct this? I definately need to keep the lower kit on as I cannot reach the ground without it. The seat is already one off of an 8 ball (I think) so no modification can be made with the seat. Thanks in advance.
BTW, I am 5'1" so I am a pretty short woman that loves her bike!
I hope my picture shows up on this thread.
MsQueen
MsQueen is offline
post #2 of 25 (permalink) Old 07-10-2015, 09:33 PM
Motorbikerx's Avatar
Thumbs down
Originally Posted by MsQueen View Post
Hello again,
MsQueen
Its the price you pay for having a lowered bike,
Apart from winding some more preload into the rear shock which will stiffen it up. Youre just gonna have to ride slower around corners and bends. Use weight transfer hang off the bike a bit more, get your chin over near your rh mirror on rh bends.
I had to revise my riding style to suit my Vegas and its standard height with an excellent Progressive brand shock.
Wear your peg scrapers down and they wont scrape as much.
Scraping is a fact of life on a Vic cruiser and yours is worse cos its lowered.
What about thick soled boots to gain an inch or two?
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #3 of 25 (permalink) Old 07-10-2015, 09:43 PM Thread Starter
Default Issue with bottoming out only
Higher boots won't work. No problem yet with cornering, it's mainly bottoming out over bumps. I don't mind a stiffer ride so tell me more about the shocks please.
Thanks
MsQueen is offline
post #4 of 25 (permalink) Old 07-11-2015, 04:55 AM
LILMAGS500's Avatar
There is an adjustment on the shock that will add more preload to the spring , this will cause a more stiff / harsh ride but should cure the bottoming issue . Your dealer should be able to do this for you , it is a simple procedure but you need a special wrench to do it .
LILMAGS500 is offline
post #5 of 25 (permalink) Old 07-11-2015, 05:00 AM
BlueVegas's Avatar
You can upgrade your shock. Try something like the Progressive 465.
BlueVegas is offline
post #6 of 25 (permalink) Old 07-11-2015, 05:26 AM
Pjv1k's Avatar
I agree with mags, cheaper fix preloading the existing shock
2014 Pearl White cross country
2011 Mini Cooper Clubman S
Pjv1k is offline
post #7 of 25 (permalink) Old 07-11-2015, 07:30 AM
Standard shock is a POS compared with Progressive shock
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #8 of 25 (permalink) Old 07-11-2015, 07:57 AM Thread Starter
what is a "POS"?
MsQueen is offline
post #9 of 25 (permalink) Old 07-11-2015, 07:59 AM Thread Starter
Default Victory man
Does anyone in Massachusetts know of a good Victory tech in my area? I bought the bike from MOM's but would rather go to a small repair place where there is a Victory Guru.
Thanks for everyone's help and suggestions.
MsQueen
MsQueen is offline
post #10 of 25 (permalink) Old 07-11-2015, 08:02 AM
what is a "POS"?
Piece Of Shit
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
